Page 6 of 17 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 169
  1. #51
    Jul 2009
    Default Re: product filter module addon
    i have read trough all php files in the shop categorry which included TABLE_PRODUCTS_OPTIONS words, and i think they have got always kind of indicator:
    AND popt.language_id = :languageID
    AND poval.language_id = :languageID " . $options_order_by;
    what as i guess narrow question to database only to results in language of session.
    as i read trough files of this addon, i havent found any indicators like that in them, so maybe thats the reason why addon doesnt regonize languages of attributes?
    i have totally no knowledge about php, so probably if someone know how and where to put these indicators to addon files, it will work well on multilingual sites, i will be thankfull
    and as i notice, files from shop use these shortcuts popt for product option and poval for product option value, but files in addon use shortcuts like po and pov, but probably it doesnt make any diference, right?
  2. #52
    Jul 2009
    hi, so finaly i made it, by comparing how it looks like in other files - actually thats my first contact with php, so if someone can take a look if it is corect, but whats important for me, it work.
    so in addon file includes/templates/TEMPLATE/sideboxes/tpl_product_filter.php in line 35 where was
    $option_names = $db->Execute("SELECT products_options_id,products_options_name FROM ". TABLE_PRODUCTS_OPTIONS);
    i changed to
    $option_names = $db->Execute("SELECT products_options_id,products_options_name FROM ". TABLE_PRODUCTS_OPTIONS." po where po.language_id = ".$_SESSION['languages_id']);
    and in line 38 where was
    $option_names_values = $db->Execute("select pov.products_options_values_id, pov.products_options_values_name from ". TABLE_PRODUCTS_OPTIONS_VALUES_TO_PRODUCTS_OPTIONS." povp,".TABLE_PRODUCTS_OPTIONS_VALUES." pov where povp.products_options_values_id = pov.products_options_values_id AND povp.products_options_id =".$option_names->fields['products_options_id']);
    i changed to
    $option_names_values = $db->Execute("select pov.products_options_values_id, pov.products_options_values_name from ". TABLE_PRODUCTS_OPTIONS_VALUES_TO_PRODUCTS_OPTIONS." povp,".TABLE_PRODUCTS_OPTIONS_VALUES." pov where povp.products_options_values_id = pov.products_options_values_id AND pov.language_id = '" . (int)$_SESSION['languages_id'] . "' AND povp.products_options_id =".$option_names->fields['products_options_id']);
    efect is such, that in case of multilingual shops filter box shows only product attributes from language which is already in use by customer. probably it was easy to find out this, but i send these changes for people like me, who dont know php.
    by the way, i got question, if someone can explain me how to make this filter searching by only one attribute, like size?
    probably its gonna be as well easy for someone who know php
    will be thankfull
  3. #53
    Jul 2006
    Johannesburg
    Hi All, I installed this mod but found that regardless of the criteria selected no items were shown. I started debugging and modified the header_php.php file a bit.
    The scenario is as follows.
    1. The file as contained in the downloads folder will only work IF YOU HAVE ATTRIBUTES loaded against your products. I do not make use of attributes but I did like the idea of having a Price and Category search on my site.
    2. In the downloaded version there was a reference to a ZS_table. I fixed this by changing it to the correct variable so you no longer have to change the table prefix, it will be done for you.
    To install this "fix" just override the header_php.php file contained in the contribution with the following:
    * header_php.php
    *Zen Cart product filter module
      *Johnny Ye, Oct 2007
    * update by Jan Cabicar, Apr 2009
    require(DIR_WS_MODULES . zen_get_module_directory('require_languages.php'));
    $error = false;
    $missing_one_input = false;
    if (isset($_GET['categories_id'])  && !is_numeric($_GET['categories_id'])){
      $error = true;
      $messageStack->add_session('filter', ERROR_AT_LEAST_ONE_INPUT);
    	$categories_id ='';
    $available = 'yes';
    $option_ids = array();
    $option_values = array();
    foreach($_GET as $key => $value){
        if(substr_count($key,'options')>0)
    		$option_ids[sizeof($option_ids)] = str_replace('options_','',$key);
    		$option_values[sizeof($option_values)] = $value;
      if (isset($_GET['categories_id'])) {
        $categories_id = $_GET['categories_id'];
      if (isset($_GET['price_range'])) {
        $price_range = $_GET['price_range'];
      if (isset($_GET['available'])) {
        $available = $_GET['available'];
      if (isset($_GET['sort'])) {
        $sort = $_GET['sort'];
      $price_check_error = false;
      if (zen_not_null($pfrom)) {
        if (!settype($pfrom, 'float')) {
          $error = true;
          $price_check_error = true;
          $messageStack->add_session('filter', ERROR_PRICE_FROM_MUST_BE_NUM);
    $define_list = array('PRODUCT_LIST_MODEL' => PRODUCT_LIST_MODEL,
                         'PRODUCT_LIST_NAME' => PRODUCT_LIST_NAME,
                         'PRODUCT_LIST_MANUFACTURER' => PRODUCT_LIST_MANUFACTURER,
                         'PRODUCT_LIST_PRICE' => PRODUCT_LIST_PRICE,
                         'PRODUCT_LIST_QUANTITY' => PRODUCT_LIST_QUANTITY,
                         'PRODUCT_LIST_WEIGHT' => PRODUCT_LIST_WEIGHT,
                         'PRODUCT_LIST_IMAGE' => PRODUCT_LIST_IMAGE);
    asort($define_list);
    $column_list = array();
    reset($define_list);
    while (list($column, $value) = each($define_list)) {
      if ($value) $column_list[] = $column;
    $select_column_list = '';
    for ($col=0, $n=sizeof($column_list); $col<$n; $col++) {
      if (($column_list[$col] == 'PRODUCT_LIST_NAME') || ($column_list[$col] == 'PRODUCT_LIST_PRICE')) {
        continue;
      if (zen_not_null($select_column_list)) {
        $select_column_list .= ', ';
      switch ($column_list[$col]) {
        case 'PRODUCT_LIST_MODEL':
        $select_column_list .= 'p.products_model';
        case 'PRODUCT_LIST_MANUFACTURER':
        $select_column_list .= 'm.manufacturers_name';
        case 'PRODUCT_LIST_QUANTITY':
        $select_column_list .= 'p.products_quantity';
        case 'PRODUCT_LIST_IMAGE':
        $select_column_list .= 'p.products_image';
        case 'PRODUCT_LIST_WEIGHT':
        $select_column_list .= 'p.products_weight';
    // always add quantity regardless of whether or not it is in the listing for add to cart buttons
    if (PRODUCT_LIST_QUANTITY < 1) {
      if (empty($select_column_list)) {
        $select_column_list .= ' p.products_quantity ';
      } else  {
        $select_column_list .= ', p.products_quantity ';
    // Notifier Point
    $select_str = "SELECT DISTINCT " . $select_column_list .
                  " m.manufacturers_id, p.products_id, pd.products_name, p.products_image, p.products_price, p.products_tax_class_id, p.products_price_sorter, p.products_qty_box_status ";
    $from_str = " FROM " . TABLE_PRODUCTS . " p, " . TABLE_PRODUCTS_DESCRIPTION . "  pd, " . TABLE_PRODUCTS_TO_CATEGORIES . " p2c, " . TABLE_PRODUCTS_OPTIONS . " po , " . TABLE_PRODUCTS_OPTIONS_VALUES . " pov ";
    $order_str='';
    $listing_sql = $select_str . $from_str . $where_str . $order_str;
    $listing_sql = "select DISTINCT ";
    $listing_sql .= "p.products_id, pd.products_name, p.products_price, p.products_tax_class_id, p.products_image, p.products_price_sorter, p.products_qty_box_status ";
    $where_str = " WHERE (p.products_status = 1  ";
    $enable_price_filter = true;
    switch($price_range){
    	case 0:
    		$pfrom = MIN_PRICE;
    		$pto = MAX_PRICE;
    	case 1:
    		$pfrom = PRANGE1_MIN;
    		$pto = PRANGE1_MAX;
    	case 2:
    		$pfrom = PRANGE2_MIN;
    		$pto = PRANGE2_MAX;
    	case 3:
    		$pfrom = PRANGE3_MIN;
    		$pto = PRANGE3_MAX;
    	case 4:
    		$pfrom = PRANGE4_MIN;
    		$pto = PRANGE4_MAX;
    	case 5:
    		$pfrom = PRANGE5_MIN;
    		$pto = PRANGE5_MAX;
    if(SHOW_SORT){
    	switch($sort){
    		case 0:
    			$order_str = " order by p.products_date_added DESC, p.products_date_available DESC, products_price ASC ";
    		case 1:
    			$order_str = " order by p.products_date_added ASC, p.products_date_available ASC, products_price ASC ";
    		case 2:
    			$order_str = " order by p.products_price ASC, p.products_date_added DESC, p.products_date_available DESC ";
    		case 3:
    			$order_str = " order by products_price DESC, p.products_date_added DESC, p.products_date_available DESC  ";
    if($categories_id !=''){
    	$where_str .=" AND p2c.categories_id = ".$categories_id;
    if($enable_price_filter){
    	$where_str .= " AND p.products_price >= ".$pfrom;
    	$where_str .= " AND p.products_price <= ".$pto;
    if($available=='yes'){
    	$where_str .= " AND p.products_quantity > 0 ";
    $where_str .=" AND p.products_id = pd.products_id";
    $where_str .=" AND p.products_id = p2c.products_id)	";
    $listing_sql .= $from_str;
    $listing_sql .= $where_str;
    $listing_sql .= $order_str;
     $listing_sql
    //$breadcrumb->add('title');
    // This should be last line of the script:
    Thank you to the original author for this great mod.
  4. #54
    Aug 2009
    Has anyone fixed the problem of filtering subcategories?
    For example:
    All Categories - Sub -- Subsub --- Subsubsub
    The filter only works in "All Categories" and "Subsubsub" - only if Subsubsub contained products.
    Sub and Subsub will not filter if no product listed in these subcategories.
  5. #55
    Aug 2009
    how can I use this module in zencart ver 1.3.0.2?
  6. #56
    Apr 2008
    Flint, Michigan
    I have been trying to get this mod working. Went through this forum and still will not work.
    Error looks like this:
    1104 The SELECT would examine more than MAX_JOIN_SIZE rows; check your WHERE and use SET SQL_BIG_SELECTS=1 or SET SQL_MAX_JOIN_SIZE=# if the SELECT is okay
    in:
    [select count(distinct p.products_id) as total FROM products p, products_description pd, products_to_categories p2c, products_attributes pa, products_options po , products_options_values pov WHERE (p.products_status = 1 AND p.products_quantity > 0 AND p.products_id = pd.products_id AND pd.language_id = 1 AND p.products_id = p2c.products_id) ]
    Any suggestions?
    Thanks, Kim
    [FONT="Tahoma"]kburner[/FONT]
    Burner Christian Bookstore
    www.burnerbooks.com
  7. #57
    Jul 2006
    Cardiff, Wales
    Excellent Mod... so many sites have this feature so great to see it on Zencart... Just a couple of issues I had though, one is already reported but not fixed...
    1) In header_php.php line 146 you need to change reference to zs_products_attributes to TABLE_PRODUCTS_ATTRIBUTES to make sure this works with any named table
    from
    $where_str .= " AND ((pa.products_id In (SELECT pa.products_id FROM zs_products_attributes pa WHERE (";
    $where_str .= " AND ((pa.products_id In (SELECT pa.products_id FROM " . TABLE_PRODUCTS_ATTRIBUTES . " pa WHERE (";
    2) This did not work for me right away, it did not filter. It took me a while to see in your code you have:
    $enable_attribute_filter = false ;
    $enable_price_filter = false ;
    I could not see in Admin where to turn this on, the instructions say nothing. So I had to change the above to true so it would work.
    Is this correct??? If its in Admin where is it, if you have to change the above can you add it to instructions?
    Apart from that is working great and is a good little mod. Thanks.
  8. #58
    Mar 2009
    Hey there,
    I've been trying to get this mod working for the last couple of days. I really like what it does (despite the fact I haven't got it quite working perfectly yet!) but I'd like to have a go at adapting the code slightly for my own needs. The problem is I'm having a bit of trouble figuring out exactly whats happening in the includes\modules\pages\product_filter_result\header_php.php.
    I think I can understand all the other files associated with this mod and what they are meant to be doing but the header_php.php has me a bit confused. I don't suppose anyone who knows would fancy adding comments to the code?
    Hi there, I have this mod installed and it looks like it works ok. The only problem is that I had SimpleSEO-URL installed and I had to turn it off to make this mod work. Is there anyway to have the two mods working together? What would be required? I'd pay someone if they could do this for me or even help me to do it myself
    cheers
  10. #60
    May 2009
    Well, here's a new one that nobody has posted about. Strange because I know the field "master_categories_id" does exist in the table "zen_products" (this is the correct table prefix in my installation).
    If anybody can point me in the right direction, I'd greatly appreciate it. Here is the error below. Doesn't matter what category you search or price range, it always is a problme with "p.master_categories_id"...
    1054 Unknown column 'p.master_categories_id' in 'on clause'
    in:
    [select count(distinct p.products_id) as total FROM zen_products p, zen_products_description pd, zen_products_to_categories p2c, zen_products_options po , zen_products_options_values pov LEFT JOIN zen_hide_categories h ON (p.master_categories_id = h.categories_id) WHERE (h.visibility_status < 2 OR h.visibility_status IS NULL) AND (p.products_status = 1 AND p2c.categories_id = 700 AND p.products_price >= 0 AND p.products_price <= 1000000 AND p.products_quantity > 0 AND p.products_id = pd.products_id AND p.products_id = p2c.products_id) ]
  1. Function of Module Manager addon
    By alimtlai in forum All Other Contributions/Addons
    Last Post: 21 Jan 2009, 09:37 AM
  2. Paypal Recurring Billing Module installation problems with addon
    By SageSystems in forum Addon Payment Modules
    Last Post: 14 Dec 2008, 05:01 AM
  3. Newbie's learning: which module or addon is it?
    By sinobeta in forum General Questions
    Last Post: 6 Sep 2008, 10:08 AM
  4. Replies: 0
    Last Post: 31 Aug 2006, 09:15 PM
