Page 177 of 222 FirstFirst ... 77127167175176177178179187 ... LastLast
Results 1,761 to 1,770 of 2217
  1. #1761
    Mount Maunganui, New Zealand
    Default Re: Tabbed Products Pro (TPP) Contrib - Official Thread
    How do I go about just changing tab images to one of the included ones in 1.08?
    And change font colour too on tab?
    Couldn't spot anything in the 'how to use'...
    Don't know my way around css but can try if I know what file etc.
    To answer my own silly question:
    At the bottom of TPP-Config in admin, is TPP Stylesheet. Change that to one of the included numbers.
    Font changes with each sample as does button...
    So if you've also read through the current 177 odd pages of this and spotted tricky css changes etc, try the easy way first! :)
  3. #1763
    Not able to answer this one myself though...
    Have the mod set up and working for Product - General.
    We also use Document - Product but can't get that working.
    In admin under TPP pages to enable, I have copied the sample there but doesn't work.
    Just not sure what to put in for Document-Product page type?
    Appreciate any help.
  4. #1764
    Jun 2012
    Quote Originally Posted by DivaVocals View Post
    You just have to make sure you remove all the previous TPP database entries..
    First Thanks DivaVocals for putting together 1.08a Unfortunately, I too have a blank Adming configuration. I've read all the forum pages on this (wow 177 pages). Most advice is to make sure all previous versions are uninstalled and all DB entries removed. However, I've just created a new site and a new DB without anything else added. So there can't be any previous versions installed.
    I do have an old site pointing to an old DB using 1.08 that has Config->TPP -config and show proper admin entries. In the 1.08a verions I have Congfig -> Tabbed Products Pro - Configuration but doesn't show anything on the page.
    How does one fix this? How does one use the auto installer for TPP?
    Also, would love to know if anyone has any examples of coding for some tabs they've created? I the tabs and their contents here http://www.barkandstuff.com/shop/sno...ith-turtleneck
    And am wondering how to get reviews inside a tab (such as review addon or something?)
    Also, does TPP work with zen lightbox?
    Thanks again!
    Mr80s.
  5. #1765
    Jun 2012
    Hello Again,
    Another thing I'm noticing is that when I add text above a tag inside the product description field before the <!--%Product Description--%> tag, it creates a second "Product description" tab. When I leave it blank above the first tag then I have only one "product description" tag. However, I thought that putting text or html code before the first <!--%> tag should put that info above the tabs on the product_info page?
    What I'm trying to do is have words beside my picture and not just in the tabs. My image is on the right and I'd like my text to be beside it on the left of the image above the tabs.
    Link is here (but it's a VM so may not always be up) http://mr80s.zapto.org/swag/index.ph...&products_id=2
    Thanks for any help!
    Mr80s
  6. #1766
    Jun 2012
    Well I finally got it resolved. I had to uninstall SQL using 1.08a uninstall, then use the 1.08 SQL and use the Admin ->tools -> Install SQL patches
    Now I have an admin-TPP Config. Yay..
    I also figured out the Global Product Description tab to move the text above the first <!--% tag out of the tabs. Helps once you get an Admin consol working :)
    Now, can someone please help with the css styling? I think it's in stylesheet.css and it's the .back attributes. What I would like is the text above teh tabs to be aligned left of the image. Actually, I just played a little more...if I set attributs on tab to yes (1) then the attributes move to their own tab as expected but then text above the first tag move to where you expect...beside the image...hmmm more playing to do but it's late.
    Nice work!
  7. #1767
    Default Tabbed Products Pro (TPP) v1.09 ready!
    I've updated the Zen Cart v1.5 ready version of TPP that doesn’t REQUIRE the CSS/JS Loader. (Tabbed Products Pro (TPP) v1.09) It will be posted on my site later today, and submitted to the downloads section as soon as I finish cleaning up the rest of the readme file. (Install instructions are complete)
    Thanks to examples I "borrowed" from the venerable niccol, I was able to re-work and improve the auto installer. There is no need for any external SQL install or uninstall files.. The auto-installer will now remove previous versions of TPP from the database completely (especially versions 1.06 - 1.08).
    You will need to remove all previous versions of TPP and CSS/JS Loader files before installing TPP v1.09. (If you want to use the the CSS/JS Loader, you should consider downloading the latest version from the current author's site and install it separately from TPP)
    I posted this because I thought others would find it useful.. It's been VERY well tested, but your mileage may vary.. I will NOT be providing any support for this..
  8. #1768
    Default Re: Tabbed Products Pro (TPP) v1.09 ready!
    Submitted to the downloads.. In the meantime you may download from my site.
  9. #1769
    Aug 2010
    I'm having a problem downloading the plugins and dont know why it keeps saying that I'm trying to download to fast, maybe someone here could shed some light on this. In the meantime I would like the URL to the Tabbed Products Pro mentioned above if possible. Please help!
    kaycee
  10. #1770
    Quote Originally Posted by kaycee View Post
    kaycee
    The link to my site is in my signature.. (See FREE DOWNLOADS on my site)
  1. Main Image Replacer (MIR) Contrib - Official Thread
    By qhome in forum All Other Contributions/Addons
    Last Post: 5 Aug 2017, 02:47 AM
  2. v154 Tabbed Prod Pro (TPP): Adding Anchor Links
    By Feznizzle in forum All Other Contributions/Addons
    Last Post: 30 May 2016, 07:50 PM
  3. v139h Conflicts between Tabbed Home and Tabbed Products Pro v1.07
    By swdynamic in forum All Other Contributions/Addons
    Last Post: 14 Sep 2014, 06:29 PM
  4. Column Divider Pro (CDP) Contrib - Official Thread
    Last Post: 3 Nov 2013, 07:44 AM
  5. Tabbed Products Contrib [WIP]
    Last Post: 22 Sep 2008, 01:43 AM
