Results 11 to 20 of 21
    Jan 2008
    Default Re: Payment, Shiping , order total dead links.
    The /admin/modules.php script accesses the filesystem to enumerate the files in the /includes/modules/MODULE_TYPE folder(s).
    If you have odd files in there, or a *lot* of files in there, I'd anticipate potential problems. But the default of 5-10 files shouldn't pose any problems.
    what files do you have in the /includes/modules/payment, /includes/modules/order_total, /includes/modules/shipping folders?
    Only the defaults that come out iof the install.....
    Jan 2008
    Quote Originally Posted by wilt View Post
    can you post the contents of your admin/includes/configure.php (less any passwords etc)
    Seems like it is not looking in the right directory to enumerate the module files,
    * @package Configuration Settings circa 1.3.8
    * @copyright Copyright 2003-2007 Zen Cart Development Team
    /*************** NOTE: This file is similar, but DIFFERENT from the "store" version of configure.php. ***********/
    // Main webserver: eg-http://www.your_domain.com -
    // HTTP_CATALOG_SERVER is your Main webserver: eg-http://www.your_domain.com
    // HTTPS_CATALOG_SERVER is your Secure webserver: eg-https://www.your_domain.com
    * If you desire your *entire* admin to be SSL-protected, make sure you use a "https:" URL for all 4 of the following:
    define('HTTP_SERVER', 'http://store.rpmhobbiesonline.com');
    define('HTTPS_SERVER', 'https://store.rpmhobbiesonline.com');
    define('HTTP_CATALOG_SERVER', 'http://store.rpmhobbiesonline.com');
    define('HTTPS_CATALOG_SERVER', 'https://store.rpmhobbiesonline.com');
    define('DIR_WS_ADMIN', '/zen/admin/');
    define('DIR_WS_CATALOG', '/zen/');
    define('DIR_WS_HTTPS_ADMIN', '/zen/admin/');
    define('DIR_WS_HTTPS_CATALOG', '/zen/');
    define('DIR_FS_ADMIN', '/www/store.rpmhobbiesonline.com/zen/admin/');
    define('DIR_FS_CATALOG', '/www/store.rpmhobbiesonline.com/zen/');
    define('DB_TYPE', 'mysql');
    define('DB_PREFIX', '');
    define('DB_SERVER_USERNAME', '#######');
    define('DB_SERVER_PASSWORD', '########');
    define('DB_DATABASE', 'RPM_zencart');
    define('USE_PCONNECT', 'false');
    define('STORE_SESSIONS', 'db');
    // for STORE_SESSIONS, use 'db' for best support, or '' for file-based storage
    define('DIR_FS_SQL_CACHE', '/www/store.rpmhobbiesonline.com/zen/cache');
    // EOF
    Jan 2008
    You asked earlier about your PHP and CURL versions.
    I don't see anything wrong with your CURL version, but I would suggest that you upgrade to one of the newer (5.2.x) versions of PHP, since the industry is moving that direction quickly ... and even Zen Cart will require 5.2 in order for v1.4 to run when it's released.
    But that should be causing your current problem.
    I have the newer PHP d loaded....I figured since it green lighted me, I could use that one.....but I am prepared to upgrade if you think we need to....
    I looked at the dirs they seem right....but I HAVE to be missing something..
    3
    Is the server's own errorlog reporting anything?
    Does the server's CPU load go up during the wait?
    Jan 2008
    Nothing in the logs.....it blips the cpu for second thats it.........seems like it never gets there....
    Jan 2008
    I am off to build PHP 5.2.5 and recompile it in.......we will see.
  7. #17
    Jun 2003
    Newcastle UK
    if you feel up to editing a file and putting in some debugging code. You could try this,
    you need to edit admin/modules.php
    find this block of code circa line 156
      $file_extension substr($PHP_SELFstrrpos($PHP_SELF'.'));
    $directory_array = array();
      if (
    $dir = @dir($module_directory)) {
        while (
    $file $dir->read()) {
          if (!
    is_dir($module_directory $file)) {
            if (
    substr($filestrrpos($file'.')) == $file_extension) {
    $directory_array[] = $file;
    and change to
      echo "<br><br>####" $module_directory;
      if (
        while (
          echo
    "<br><br>" $file;
          if (!
            if (
    now when u got to the modules section of admin, for payment/shipping etc you should see extra information echoed to the browser.
    That might give some hint as to what the problem is.
  8. #18
    Jan 2008
    No joy when editing the modules.php file.
    I took a nap, and I think I may have the answer. My upstream provider in the Data center where I am collocated uses SNORT and a perimeter defense. I have had issues with it before being too tight for some code ....especially when it involves SSL.
    So my theory is that because I chose not to enable SSL at the build up the activity with curl looks like something SNORT should block as it is outside of SSL.
    Make any sense at all???
    Anyway I have fired off a ticket to my buddies at the data center and we will see.
    I will be sure to post back as to the outcome.
    Thanks gents.
    Mike
  9. #19
    Jun 2003
    Newcastle UK
    While a CURL problem might affect the loading of some payment/shipping methods, It should not affect the loading of modules generally.
    Does you problem occur for every type of module.
    ie shipping, payment and order totals.
    However I am not that familiar with SNORT so cannot say whether it is having some other effect.
  10. #20
    Jan 2008
    Just to bring closure to this ticket. It was in fact some odd rule in SNORT regarding "modules.php".
    Since we use the screw it down tight until someone complains mentality towards security, we had all of the SNORT rules ON.
    Anyway after determining that the modules.php the rule was designed for was obviously NOT the oscommerce/zen cart flavor..... we opened it for up for use and presto everything works great now.
    Thanks folks for your time and attention to this.
    TalonOne
    Over and out
  1. The Modules of Payment, Shipping and Order total are missing
    By yuxiaomao in forum Built-in Shipping and Payment Modules
    Last Post: 8 Dec 2007, 05:33 PM
  2. Payment from Paypal Doesn't Equal Order Total
    By friends1976 in forum General Questions
    Last Post: 29 Jun 2007, 05:42 AM
  3. Zero Order Total still requires Payment Method
    By gmoyle in forum Setting Up Categories, Products, Attributes
    Last Post: 1 Oct 2006, 04:29 PM
