Page 6 of 25 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 241
  1. #51
    Jun 2008
    Canada
    Default Re: Canada Post module
    Quote Originally Posted by prissypups View Post
    I have the mod installed now however it is not calculating the costs correctly.
    My first question is does it use the server / login to pull info from? If so that is the problem as we are waiting for the login etc.
    I added a weight to an item to test. .200 and have letter mail enabled however it is 8.90???? should be like 3$??
    any help? or advice to what i am doing wrong.
    Hello Prissypups,
    Information taken from Sellonline.ca. As soon as you get your login information from Canada Post.
    Set up your box and envelope.
    (Envelope) Lettermail Dimensions
    Length: Minimum - 14 cm (5.51 in.), Maximum - 38 cm (14.96 in.)
    Width: Minimum - 9 cm (3.54 in.), Maximum - 27 cm (10.63 in.)
    Height: Minimum - 0.018 cm (0.007 in.), Maximum - 2 cm (0.78 in.)
    Weight: Maximum - 500 g (1.1 lb.)
    Also noticed many options you talk about are not in the mod? why do I not see it?
    What options?
  2. #52
    Mar 2009
    Hey
    Ok I got the login info all set up, however in regards to setting up the boxes etc.. I click add/modify/del boxes however there is no min/ max settings etc.. can anyone advise?
    thx
    Jim
  3. #53
    Mar 2009
    Hey
    Ok I played with the setting s bit and seem to get the numbers close in regards to shipping fees. I do have a few questions that I need clarified if possible.
    What is the diff between expedite vs regular vs priority?
    Why does xpress post not show for me despite being checked on in the CP site?
    In regards to calculating costs.. where does the mod draw the amounts from? is from the CP server or from the numbers I input into the options?? how do I know what numbers to put in. at the momment I have it at default.
    As for packaging for us our envelops we sell are 14.5" x 9.5" and will fit through regular mail. (depending on the number of dog outfits in it).
    What should the settings be? typically 1 item for us is 250 grams.
    can anyone clarify? is there a way to verify that it is calculating correctly?
    thanks v much
    Jim
  4. #54
    Apr 2009
    Quote Originally Posted by Royal View Post
    Yes! When choose Xprespost, Priority Courier and Regular Parcel on Sellonline. Xpresspost show.
    Great tip. Fixed my problem.
  5. #55
    Feb 2008
    Is there a way to set kg/cm as the DEFAULT selection in my Add Product listing - in the Canada Post portion of the add-new-listing.
    I can manually select kg/cm as I do each product listing, but the form presents with lb/in pre-selected , so its two more clicks. Not life threatening to be sure...just a little tweak I'd like to do to save the two clicks and two opportunities for me to make a mistake ;o)
    I do have my units set to kg/cm in the zc files.
  6. #56
    3
    In the collect_info.php files for that addon you'll see these lines near the top:
                           //added Canada Post start
    			           'products_weight_type' => '',
    			           'products_dim_type' => '',
    change that to:
    			           'products_weight_type' => SYSTEM_WEIGHT_UNITS,
    			           'products_dim_type' => SYSTEM_DIMENSION_UNITS,
  7. #57
    Mar 2010
    help question Re: Canada Post module
    Hi i've been using Zen Cart for a while now, installed a few mods, etc. I'm up to date on the ZC version 1.3.9 but i've just installed the Canada Post module and for some reason i'm getting "Error 110: Cannot connect to server" from sellonline. I thought it was a firewall issue but i've never encountered this issue with any other program i've run.
    Could there be another issue going on?
    Thank you,
    Louise
    http://www.soap-gallery.com
    p.s. i've had to resort to using a table :/
  8. #58
    Jun 2008
    Canada
    Hello dashmoo,
    Please make sure that your host open port 30000 bi-directionally (inbound and outbound traffic).
  9. #59
    Jun 2008
    Canada
    Hello dashmoo,
    The website in my signature is Version 1.3.9c and using Canada Post Module.
  10. #60
    Feb 2010
    I have the latest version of the cart (installed last week)
    I have the latest version of the CP add on, installed this week.
    I have 2 websites, www.australiancaching.com/store, old version of CP works fine.
    My other store, www.nacaching.com/store is on the same server, like a subdomain, I don't even get rate quotes for CP, so I know it is not a problem with the port, as the other is working.
    My CPC_ etc is set for the other store, and when I phoned CP, they confirmed that regardless of the store, it will work (my settings in CPC are linked to the Australian caching site, they say it makes no difference, either will work)
    All settings in new store seem fine, just nothing showing up.
    I would have just set up a new customer number with CP, but get the error "phone number in ust with another account" and wouldn't let me go further (I am not getting a new phone to add an account to CP)
    Any guess as to why it won't work?
    Guy
  1. Canada Post Module
    By Briank58 in forum Addon Shipping Modules
    Last Post: 26 Apr 2007, 05:32 AM
  2. Canada Post module
    By pgfox46 in forum Addon Shipping Modules
    Last Post: 14 Dec 2006, 02:25 PM
