This may have been answered several times but I have not found it. I have a problem in setting up my shipping options. I have a few different products that weight from 2lbs up to 7.5lbs.
Using the UPS and the USPS modules work fine for the single small products that can ship easily in the usps priority boxes and if someone purchases more then the weight makes UPS a better choice for price.
BUT and this is the problem when the box size gets to big for the weight then the UPS and USPS modules don't work.
An example:
I just sold 15 wastepaper baskets that are 12"x12"x14" they weight 7.5lbs each
I put 2 per box
Total package weights (tare) 18lbs
box size 18"x18"x28"
If the total of the w x l x h exceeds 5,824 cubic inches, UPS uses the the total width x length x height /194 to get the cost which in this example is 47 which means the package is based on 47lbs.
So the shipping charge is $48.50 not $11.59 like the estimator module shows.
What can I do to make a work around for this.
I have now set the max weight at 9lbs. The tare is 5:.8
I do appreciate all your help
RJ![]()
