Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
  1. #31
    Apr 2008
    Flint, Michigan
    Default Re: craftysyntax Live Help module HELP!
    Quote Originally Posted by Royal View Post
    Hello KBurner,
    Add www and see if that works: https://www.burnerbooks.com/livehelp/livehelp_js.php?eo=1&department=1&serversession=1&pingtimes=15&secure=Y
    I turned off both newsletter and Live help sideboxes and YaH no more secure/non-secure messges. But also means I do not have both at all in my shop.
    Does anyone else have any more suggetions??
    Thanks, Kim
    [FONT="Tahoma"]kburner[/FONT]
    Burner Christian Bookstore
    www.burnerbooks.com
  2. #32
    Apr 2008
    Flint, Michigan
    Quote Originally Posted by vwebworld View Post
    Hi Kevin,
    Yeah, I tried both with and without SSL.
    I ended up just making a link to the live help and used that in my ZenCart sidebox.
    houseofjerky.net/store
    ~Roland
    How did you get your business name in live help box that opens to new window for link?
    Kim
    www.burnerbooks.com
  3. #33
    Nov 2009
    Chicago, IL.
    Whoever is looking for an answer to the above mentioned question:
    you can change Powered By : craftysyntax.com to anything you like by editing the file user_top.php
  4. #34
    Jan 2010
    You may try another live chat software. Comm100 Live Chat is free and easy to integrate with. Simply paste several lines of code, then you can start chatting.
    http://www.comm100.com/livechat/
  5. #35
    Jun 2010
    Quote Originally Posted by shocker View Post
    There are some code syntax error in the tpl_craftysyntax_sidebox.php file that's in the download.
    There are two lines that need to be edited. the line numbers I give are not exact.
    around line 57 should be
    $cs_link = $cs_dir . '/' . 'livehelp_js.php?department=' . $cs_dept . '&pingtimes=' . $cs_pingtimes . '&username=' . $cs_full_name;
    around line 60 should be
    $cs_link = $cs_dir . '/' . 'livehelp_js.php?department=' . $cs_dept . '&pingtimes=' . $cs_pingtimes;
    If you notice, the original two lines have a '/' . after the = symbol. This causes the source string to the livehelp_js.php to be incorrect. For instance:
    <script type="text/javascript" src="/http://www.nahidfashions.com/livehelp/livehelp_js.php....
    will not work because of the / before the http://
    I'm still working configuring and tweaking, but after making this change the Crafty Syntax shows in its side box.
    I hope this is clear and helps all.
    thanks solved my issue!!
  6. #36
    Oct 2010
    Hiya All
    Ive installed this software and sidebox and all seems to work great, i love the features.
    Only problem is when i login it doesnt take my username for the live chat, it still asks me to type my name in, what could be wrong?
  7. #37
    Jun 2010
    Quote Originally Posted by Sophia Myles View Post
    Hi could you please help me out installing Comm100, I have no idea where to paste the code. I've tried the craftysyntax sidebox but I don't know where I am supposed to paste the comm100 code.
  8. #38
    Dec 2010
    Hi magicman,
    could you please elaborate "Generate the code from Crafty Syntax program" ? How do we generate ? Is it copy the display html code from http://www.mydomain.com/livehelp/livehelp_js.php, and replace the text: "You can include text, links, images, HTML markup and even PHP code"
    regards,
    Sky
  9. #39
    Oct 2007
    MA, USA
    It has been so long since I installed it. I will have to take another look at the coding. Sit tight.
    Thank you, Sincerely, MagicMan
  10. #40
    Dec 2009
    Gold Coast, Australia
    Does this work with 1.5.0 if not is there another 100% free one that does work.
  1. Live chat Module?
    By jrod31 in forum All Other Contributions/Addons
    Last Post: 12 Dec 2013, 12:04 AM
  2. Need Help with Crafty Live Help Module
    By chrisb in forum General Questions
    Last Post: 14 Jan 2008, 08:04 PM
  3. Replies: 2
    Last Post: 17 May 2006, 09:44 PM
