Re: Reset customer password from admin
ken1
I just installed Reset--Customer-Password on Zen Cart 1.5.4.
I changed the admin folder name to my admin folder name.
I copied pasted and sent the SQL add_admin_menu_entry-v15xsql
Either it didn't work or I just don't know where to find it.
Can someone tell me where it is suppose to be.
k
What version of Zen Cart do you have?
Where did paste teh sql file? It should have been in Tools>Install SQL Patches
The Zen Cart version is 1.5.4 and yes the patch was installed in Tools>SQL Patches
If I recall, a Change Passwords option is added the the Tools menu.
You are right. I didn't know where to look. I found it under tools and it works.
I appreciate the help.
ken
I did this, everything loaded OK, but the Master password returns this error
Error: Sorry, there is no match for that email address and/or password.
stevesh
Copy and paste the contents of pass.sql into Admin - Tools - Install SQL Patches then click Send.
Then drag and drop the 'includes' folder in the mod to the root dirctory of your site.
I went to MY Store and changed the Master Password, but it is not working. Any ideas?
johnniejetski
This is not the master password support thread. This plugin resets customer passwords.
@jeking, just wanted to report a bugfix to you. I'm using Admin Profiles, and realized that enabling 'Change Customer Password' from the profile editor did not actually give access to my client's admin account. I found that the page key had a capital 'C' (passChange), but it should be lowercase to allow access to passchange.php.
Here is the updated SQL that worked for me:
INSERT INTO admin_pages (page_key, language_key, main_page, menu_key, display_on_menu, sort_order) VALUES ('passchange', 'BOX_TOOLS_PASSCHANGE', 'FILENAME_PASSCHANGE', 'tools', 'Y', '40');
jackie.taferner
Thanks for the report and the fix.
