Hi everyone,
First of all I am using Zen Cart 1.38 also I have looked at the multisite module and it is not what I am after too complicated as no need for that.
I have two sites on same server and they will be duplicates with just different domain name. I have already installed them they are using the same database with no problem.
As I will only be using one admin and both sites belong to the same person there is no need for changing anything else.
The only problem is the product images. How can I pull the images from one site to the other? I have tried to change the config files and got them to work but they only show distorted and the pop up shows the images small. I have tried in adding the images on both sides and they show fine only when I pull them from the one site to the other happens. As such I am thinking that maybe I missed something.
Is there anywhere else other than the config files that the product images folder is defined?
Tassos
