    Nov 2005
    Vancouver, Canada
    Default i have description showing up in product listing, but not on Product info
    Quick little question. I have no product description showing.
    I'm using 1.3.8 for the first time. I installed the cherry zen template and customized this layout.
    i have description showing up in product listing, but not on Product info. I want this switched around.
    the site is http://www.leladesigns.ca/shop-lela/...ndex&cPath=1_2
    I'm also a little confused with the image sizes. when i click on show large image, the popup is blank. But as I close the popup, the image flashes very quickly and the popup closes.
    Am I missing something? I know it's the weekend and 30C outside, but really, my brain is not fried.
    Default Re: i have description showing up in product listing, but not on Product info
    Well I see for Jenny Track Pants prod info below the contact us
    Flattering straight cut fit with sleek pintucks down the side seams to make those legs look even longer. Perfect comfy pants that say ########. Elastic and drawstring add extra adjustability. Makes a perfect pair with the Betty hoodie.
    Nov 2005
    Vancouver, Canada
    Kobra:
    thank for the response. I turned on/off some switches in admin and it showed up. I
    I have one more question, the site template was originally set up to use add to cart button, but now got replaced with contact us. how can i change this back? I know my way around zen pretty well, but can't seem to find the silly switch.
    hope you're enjoying the summer. Here's it's a scorcher.
    admin > my store > store status > should be set to "0"
  1. Remove Product listing Product Description, and replace with stock info
    By SethF in forum Templates, Stylesheets, Page Layout
    Last Post: 30 Jan 2012, 10:27 PM
  2. Add more info link to product listing description when description is truncated
    By MaureenT in forum Templates, Stylesheets, Page Layout
    Last Post: 16 Sep 2010, 05:44 PM
  3. I have problem with disable description in product listing
    By pckomplet in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Jul 2009, 04:28 PM
  4. product listing to show description but not name
    By yaby in forum Templates, Stylesheets, Page Layout
    Last Post: 2 Dec 2008, 01:31 AM
  5. Product description in product more info in html format but not in product listing?
    By this side up in forum Customization from the Admin
    Last Post: 18 Dec 2006, 06:25 PM
