Results 1 to 7 of 7
    Jun 2008
    Default Newbe Needs A Little Help
    First off, this has been a pretty easy program to figure out so far. I haven't done anything crazy, but my abilities are very limited. I have everything up and running ok for the most part, but I keep getting "Returned Email:See Transcript For Detail" emails. When new customers sign up, I always get this email:
    The original message was received at Tue, 1 Jul 2008 12:36:54 -0700
    from localhost.localdomain [127.0.0.1]
    ----- The following addresses had permanent fatal errors -----
    <Budthugin69##################>
    (reason: 553 sorry, your mail was administratively denied. (#5.7.1))
    ----- Transcript of session follows -----
    ... while talking to relay-hosting.secureserver.net:
    >>> MAIL From:<dieselhardware##########################> SIZE=1891
    <<< 553 sorry, your mail was administratively denied. (#5.7.1)
    501 5.6.0 Data format error
    The rest is the welcome email message. Anyone got any clue as to how I can get this fixed? Thanks a bunch in advance, this site has been very helpful in getting my first business up and running online.
    Mar 2007
    AZ
    Default Re: Newbe Needs A Little Help
    Check your email settings. You may have a setting selected that your host doesn't like. You may need to set up cURL settings for proxy too - depending on who you are hosted with.
    Tina
    Jun 2008
    Quote Originally Posted by charmedbytina2 View Post
    Tina
    Hosted with godaddy.com right now.
    Jun 2008
    Did some more playin around just now and got it figured out!
    N of San Antonio TX
    and the solution....
    You might just help someone with the same problem.
    A little help with colors.
    Jul 2008
    Yes please... I just discovered the same problem and use godaddy.
    thanks!
    Carol
    Jul 2008
    I got it to work...
    I added a new email address with GoDaddy for the store and then used that email@domain_name.com instead of ISP email address.
    Then changed EMAIL ADDRESS to email@domain_name.com... instead of ISP email address...
    The test message seemed to work but I have not turned any CC email options on.
    Carol
  1. Newbe Needs Help
    By Slicer5489 in forum General Questions
    Last Post: 11 May 2010, 10:40 AM
  2. Newbe needs help please
    By tropicalfirearms in forum Templates, Stylesheets, Page Layout
    Last Post: 23 Feb 2009, 04:58 AM
