Results 1 to 10 of 13
    Jul 2008
    Default Globally Changing prices of products.
    Hi all, hope you can help me :)
    I have a shop with 1500 products in it, and have to alter the price of them all by a set % is there an easy way to do this?
    The items are in categories and subcategories. I was thinking that maybe I could export them to a spreadsheet, alter them globally, then upload the new file? Any advice appreciated as I am a total noob with this
    T
    Default Re: Globally Changing prices of products.
    Are you wanting to alter all 1500 products by the same % or each category of products?
    Do you have attributes with prices or just product prices?
    Jul 2008
    Hi , this has now been done thanks
    Mar 2008
    Linda's hesitance in immediately suggesting EasyPopulate is well-placed... If you're just working with basic product data (none "priced by attributes"), then EasyPopulate enables "mass updating" using a tab-delimited txt spreadsheet.
    If you have products whose pricings are also dependent on attributes (sizes of a particular garment, for example), then EasyPopulate has some limitiations.
    There are also ways to do updates on prices in part or as a whole depending on what the criteria is ...
    For example, update all prices by plus 10% is a single command ...
    Update all prices in a given category where the category is the master_categories_id can also be done with a single command per master_categories_id ...
    Updating both prices and attributes can be done with a bit of coding ...
    For other things, programs like EP might be useful ...
    Jul 2008
    Well I paid a programmer to alter the prices globally and it is done, but the store has really slowed down. I have an awfull feeling he has scripted it to do this rather than altered the actual prices.
    Also all the stock levels are set to zero now
    Will easy populate allow me to globally set the stock levels?
    Is this the rright page for download ?
    http://www.zen-cart.com/index.php?ma...roducts_id=460
    T
    Jul 2008
    After consulting the zen cart owners manual (if you use Zen cart BUY THIS BOOK)
    I have discovered that you can set it to allow checkout on non stock items, and also not to show out of stock etc.
    This is perfect for dropshippers, or florists etc, wehere the stock is made at the point of sale
    GREAT BOOK!
    And no I am NOT on commission LOL
    Nov 2009
    Did you buy the hard copy book or the downloadable one? How up to date can the hard copy be vs the digital one?
    Nov 2009
    help question Re: Globally Changing prices of products.
    I was reading your advice to another new zenner and wondered where I'd find the info to do what you're describing here. I'd like to be able to change the prices or add prices to a whole category. Could you please point me in the right direction? thank you.
    george
    You can check the products table in phpMyAdmin to see what the master_categories_id is or ... in the Zen Cart Admin go to the Categories/Products ... if all the Category is not marked with a yellow icon, that means there are not any Linked Products ... if the Category is marked with a yellow icon that means there are Linked Products ...
    If you use Linked Products, check to see if those Products are all using the same master_categories_id ... you can see this by editing the Product ...
    If all Products use the same master_categories_id, then you can use that to control which Category gets the prices updated ...
    For example, if categories_id 10 is the master_categories_id you can update the products_price to $5.00 more with:
    UPDATE products SET products_price = products_price + 5.00 WHERE master_categories_id = 10;
    and that can be run in the Tools ... Install SQL Patches ...
    The, go to the Tools ... Store Manager ... and run the Update Products Price Sorter ...
    NOTE: the Update Products Price Sorter uses the master_categories_id when building the default price for the Product ... so if using Linked Products, it is important that master_categories_id be set correctly ...
  1. Can prices be added globally to a range of products or only one product at a time?
    By actionjackson57 in forum Setting Up Categories, Products, Attributes
    Last Post: 8 Aug 2011, 03:32 PM
  2. Applying Attribute Value prices Globally.
    By Sushigal in forum Setting Up Categories, Products, Attributes
    Last Post: 27 May 2011, 01:43 PM
  3. increasing prices globally?
    By bbrace in forum Setting Up Categories, Products, Attributes
    Last Post: 3 May 2011, 02:13 PM
  4. How to globally increase prices?
    By snowy2007 in forum Setting Up Categories, Products, Attributes
    Last Post: 10 Dec 2008, 11:52 AM
  5. Adjusting prices globally
    By sammybotz in forum General Questions
    Last Post: 6 Apr 2007, 03:35 AM
