Results 1 to 10 of 13
    Mar 2008
    Default Images On Homepage With Links To Products. Help Please.
    I've done a search but can't seem to find any answers as to if it's possible to add links to different images on my homepage where when you click on them they'll take you to a certain product page. Is this possible and if so could someone please tell me how as i seem to be getting no where with it.
    www.dpmperformance.co.uk
    I want it to be similar to this...
    www.rimstyle.com
    where you can click on different images direct from the homepage.
    Mar 2008
    Default Re: Images On Homepage With Links To Products. Help Please.
    This is simple HTML, using the <a href="...."> tag.
    When you add the text description to your main page, you are - in effect - inserting HTML code. Using HTMLArea (the default text editor with ZC) you can "toggle" to the source code by clicking the " <> " menu icon.
    This will display the source code.
    You can create your main page HTML in any good html editor (I use Dreamweaver).
    You establish the link code to your products by:-
    1. Calling up the relevant product in your browser.
    2. Copying the PATH to that product (it's in your browser address bar) - for example:
    HTML Code:
    http://www.yourwebsite.com/index.php?main_page=product_info&cPath=60_63&products_id=359
    3. Then, you create the image you want, and attach the above URL to it via a hyperlink:
    HTML Code:
    <a href="http://www.yourwebsite.com/index.php?main_page=product_info&cPath=60_63&products_id=359"><img height="112" src="http://www.yourwebsite.com/images/imagename1.jpg" width="180" border="0" /></a>
    See www.edutrade.co.uk for an example site where I've done this.
    Mar 2008
    I'm a total newbie to all this so sorry for the stupid questions but say for example my logo at the top of the homepage in the header, it appears in the backend as...
    <img src="images/DPM-01207561606.png" alt="DPM Performance logo" height="119" width="908">
    to get this to link to say for example my homepage...
    http://www.dpmperformance.co.uk/
    How would i go about doing this? Would it be...
    <a href="http://www.dpmperformance.co.uk/"><img src="images/DPM-01207561606.png" alt="DPM Performance logo" height="119" width="908"></a>
    Mar 2008
    Take a look at www.edutrade.co.uk
    On the main page, I have a large number of images advertising certain products. I created these in Photoshop and gave them different names, then uploaded them to a sub-directory called "mainpage" in the "images" folder.
    Look at the image on the right of my home page called CLASSIC TOYS.
    The PATH to this image is:-
    HTML Code:
    http://www.edutrade.co.uk/images/mainpage/watches.jpg
    The URL to the part of my zenshop selling classic toys is:-
    HTML Code:
    http://www.edutrade.co.uk/index.php?main_page=index&cPath=138
    So the HYPERLINK attached to this image, enabling a click to take you to that category is:-
    HTML Code:
    <a href="http://www.edutrade.co.uk/index.php?main_page=index&cPath=138"> <img src="http://www.edutrade.co.uk/images/mainpage/classictoys.jpg" border="0" width="180" height="242" /></a>
    As I said, this is basic HTML - nothing special for Zencart - so if you don't know how to use HTML then it may be worth your while to do a couple of online tutorials. There are some good free ones at W3schools.
    Mar 2008
    Ahh, that's great! Thank you so much!
    I've managed to do the logo at the top, now i just need to figure out how to split up at the images but keep them in the same position.
    Mar 2008
    Right, i know that if i just add the image source next to the image source that is already there, the new image will just go along side the exsisting image but what do i need to add before the image source to get it to put the image underneath the exsisting image?
    I thought it was just <div but that doesn't seem to be the case.
    Thanks in advance
    Mar 2008
    I'm confused about what you are trying to do. There should be no need to edit any core code.
    Where do you want these images to appear?
    Product images that accompany product text in the normal course of ZC are automatically linked - either to the More Info (detailed product info) page, or (when you are in the detailed product page) to a larger (zoomed) image.
    The RIMSTYLE website you refer to in your original post is probably using a feature similar to zencart's CATEGORY IMAGE feature - where you apply an image to a catgory.
    To do this, go to your ADMIN PANEL>>>CATEGORIES/PRODUCTS and then click on a green "E" button next to a category name. This opens the category for editing. Here, you will see features that allow you to assign an image to that category.
    Then, to get these images shown on your main page, go to ADMIN>>>LAYOUT SETTINGS>>>CATEGORIES - ALWAYS SHOW ON MAIN PAGE (set to 1)
    Mar 2008
    I don't think i explained it very well lol
    What i want to do is put another seperate image under the image which is already on the homepage but when i try to all it does is put it to the side of the image. Does that make sense?
    Mar 2008
    Quote Originally Posted by DPM View Post
    This "image which is already on the homepage" - do you mean your LOGO (header image)?
    Adding a <br /> between the two images should put you on a new line.
  1. Need help with images on homepage, please
    By Kruna in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Oct 2009, 10:28 AM
  2. Category Links to Images help please
    By imperialis in forum Templates, Stylesheets, Page Layout
    Last Post: 9 Jan 2009, 03:14 AM
  3. I need help with my homepage please
    By heartagram_aus in forum Templates, Stylesheets, Page Layout
    Last Post: 9 Aug 2007, 02:50 AM
  4. Please help me with a few broken links?
    By chrisrub in forum General Questions
    Last Post: 24 May 2007, 08:40 PM
  5. Help needed with a Flash links problem please
    By DaveG in forum Templates, Stylesheets, Page Layout
    Last Post: 22 Sep 2006, 02:49 AM
