Yes, I went through the 15 or 20 different threads relating to multiple images, but I yet cant get them right.
Details of host / Zencart install:
My Current Host has GD, but not ImageMagick.
Zencart is located here: http://shadeofcrafts.in/zenc/index.php
Product to test multiple images with is here:
http://shadeofcrafts.in/zenc/index.p...&products_id=6
I had installed IH2, it didn't work, then I added Hoverbox, which somehow cause IH2 to, well _inactivate_ (its there in the admin panel, but has the link asking for installing it)
Now I'm trying to get hoverbox working with multiple images, but it wont, neither will the multiple images in certain directory strutures.
For simplifying, I'm attaching zips of my various directory structure:
Images1.zip : Wont Work, only main image shows up
Images2.zip: Like Images 1
Images3.zip : Works, shows two images each for larger viewing, HOVERBOX shows only 1 image.
Images4: Current view at
http://shadeofcrafts.in/zenc/index.p...&products_id=6 [Hoverbox yet wont show other images, and main product shows up again at the bottom]
If I cant get it to work, I'm considering starting from scratch. I'd prefer to avoid
that. Also thinking of the code patch for IH in the bzx file.. will try it in a day or two.
Thanks for reading :)
