Results 1 to 3 of 3
    Jun 2008
    bug Shipping tare weight/boxes configuration does not work for FedEx
    My shipping is based on the FedEx module, and when I try to configure the tare weight or max box size in the configuration, shipping/packaging section, nothing changes when I test the shopping cart!
    Does this shipping/packaging section only apply to table rates or "simple" shipping calculations? Is it not working with the FedEx/USPS modules?
    Customers group items together into one large package but it actually costs a lot more than what FedEx calculates so we take a loss on these large packages. They should be split into multiple boxes but the Zen Cart shipping part is broken.
    Default Re: Shipping tare weight/boxes configuration does not work for FedEx
    Maximum weight should be the lesser of the two shipping modules on how much they will ship in one box, unless you do not mind one shutting off when the weight is too much ...
    The default is 50, for 50lbs ... if you set this higher and total weight of the order is more than 50lbs, USPS cannot ship it as the quotes will attempt to quote for a higher weight ...
    Also, check your Tare weights as these add on for small packages, by default 3 lbs ...
    Jun 2008
    Ajeh, thanks for the reply but I think the problem is misunderstood.
    Adjusting max shipping weight or tare has no effect on the shipping cost when it is used with the FedEx module. I tested with the shopping cart and it is not splitting the order into separate boxes when it should. Playing with the max weight or tare has no effect.
    The tare option talks about small sizes and large sizes. What's the difference between large and small? This is not defined anywhere. Was Zen Cart written by programmers who hate math? I don't understand how this ecommerce system can work without correct calculations and without defining values and just using vague words like "large" and "small."
  1. v138a Configuration does not work
    By Jukor in forum Basic Configuration
    Last Post: 15 Apr 2015, 11:55 AM
  2. v138a Fedex web services does not work for International
    By adolgin in forum Addon Shipping Modules
    Last Post: 17 Jun 2012, 05:13 PM
  3. v139h Per Weight Unit shipping does not work!
    By n_t_r in forum Built-in Shipping and Payment Modules
    Last Post: 21 Feb 2012, 06:45 PM
  4. Replies: 6
    Last Post: 20 Oct 2011, 03:33 AM
  5. Shipping Weight calculated incorrectly - Not Tare Settings!
    By levbeck in forum Built-in Shipping and Payment Modules
    Last Post: 23 Sep 2007, 12:40 PM
