Results 1 to 10 of 18
    Jul 2008
    Emporia, Virginia
    Default Help Help Help! I cannot login to Admin
    I ran into this trouble after installing superorders, and posted it there. I have since began to suspect that the issue is not related to that mod. I have restored everything from a backup, but still get this message when I go to the admin oage
    Warning: main(DIR_FS_CATALOG_LANGUAGESenglish/meta_tags.php): failed to open stream: No such file or directory in /home/content/c/j/a/cjayosburn1/html/Retail/admin/includes/languages/english.php on line 50
    Fatal error: main(): Failed opening required 'DIR_FS_CATALOG_LANGUAGESenglish/meta_tags.php' (include_path='.:/usr/local/lib/php') in /home/content/c/j/a/cjayosburn1/html/Retail/admin/includes/languages/english.php on line 50
    My login page is here:
    http://nwspiceco.com/Retail/admin/login.php
    and my store is at http://nwspiceco.com/Retail/index.php?main_page=
    The storefront is still apparently operational, and I still get e-mail generated by the system. I have read everything that I can find, and now all of you kind people are my last hope. I would hate to start over.
    Thank you all.
    ** EDITED *** Never ever post in a forum, email, newsletter etc. the zenid or zenAdminID or you will be doomed!!
    Sep 2004
    MONTANA!!!
    Default Re: Help Help Help! I cannot login to Admin
    I would say that line 50 is missing a character or two. Retail/admin/includes/languages/english.php
    THis should be what is there.
    require(DIR_FS_CATALOG_LANGUAGES . $_SESSION['language'] . '/' . $template_dir_select . 'meta_tags.php');
    Note the .'/' . part.
    Jul 2008
    Emporia, Virginia
    Thanks Paul-
    Tried that, no luck.
    Sep 2004
    MONTANA!!!
    OK. Is DIR_FS_CATALOG_LANGUAGES defined in your config file? Should be something like this.
    Also, check to see if DIR_FS_CATALOG is defined correctly.
    Mar 2007
    AZ
    Look at the files named in your error message - make sure there are no blank lines or spaces after the closing tags.
    Tina
    Jul 2008
    Emporia, Virginia
    Thank You Both-
    Sorry to not get back to this, but have had several other projects working. I did as you suggested, fourbit, and did finally get a login box on the admon page, but with the following errors...
    Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/content/c/j/a/cjayosburn1/html/Retail/admin/includes/configure.php:137) in /home/content/c/j/a/cjayosburn1/html/Retail/includes/functions/sessions.php on line 108
    Warning: Cannot modify header information - headers already sent by (output started at /home/content/c/j/a/cjayosburn1/html/Retail/admin/includes/configure.php:137) in /home/content/c/j/a/cjayosburn1/html/Retail/admin/includes/init_includes/init_templates.php on line 36
    My eyes have crossed from reading all that code, but will be back tomorrow.
    Thanks Again
    Jul 2008
    Emporia, Virginia
    All is fixed now, thanks to fourbit!
    Thank you both for all of your help. My store is up and running again.
    Jay
    Mar 2010
    I have the same problem too.. I know this is an old post but I really need help. This is a fresh installation so I dont mind reinstalling... I have installed the app like 4 times already trying to get rid of the error.. deleted the original DB and folder and recopied the original package. Funny thing is the first time I installed it, it worked... and I do not know why its not working anymore.
    This is my error. Can anyone help please?
    Warning: require(DIR_FS_CATALOG_LANGUAGESenglish/meta_tags.php) [function.require]: failed to open stream: No such file or directory in /hermes/bosweb/web027/b278/ipg.belovedstarsconnect/earthensprings/admin/includes/languages/english.php on line 50
    Fatal error: require() [function.require]: Failed opening required 'DIR_FS_CATALOG_LANGUAGESenglish/meta_tags.php' (include_path='.:/usr/local/lib/php-5.2.12/lib/php') in /hermes/bosweb/web027/b278/ipg.belovedstarsconnect/earthensprings/admin/includes/languages/english.php on line 50
    Sep 2004
    MONTANA!!!
    Quote Originally Posted by netnuts View Post
    Howdy,
    Yep. this is an old one. Anyhow, the "DIR_FS_CATALOG_LANGUAGES" part shouldn't be showing. It is indicating that that variable is not defined at all. Check your admin config and compare it with the dis-configure.php in the admin/includes folder. Make sure you are looking at the admin folder.
    Also, don't forget to rename that folder to something totally unguessable for security purposes.
    Paul
    Mar 2010
    Thanks for responding Paul... Apparently it either had to do with how my computer unzipped the package... I think something went wrong... because i reinstalled with a download I had from the day before and it works perfectly... I was relieved as I wasn't in the mood to dig into the code... Thanks for all your help tho... 'ppreciate it.
  1. Cannot access Admin login page after several attempts and FAQ suggestions, HELP!
    By jnb41578 in forum Installing on a Linux/Unix Server
    Last Post: 6 Jul 2011, 02:57 AM
  2. Help??? Cannot login to admin
    By arteklektrika in forum Templates, Stylesheets, Page Layout
    Last Post: 5 Jul 2009, 12:29 AM
  3. cannot login please help
    By amopro in forum Basic Configuration
    Last Post: 24 Jul 2007, 05:02 AM
  4. HELP! Cannot Admin Login
    By nextebizguy in forum General Questions
    Last Post: 10 Sep 2006, 06:12 AM
