Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Jun 2009
    Default Re: Help Help Help! I cannot login to Admin
    I've got a similar problem as well. I reinstalled my shop from a backup and now I get this error when I try to go to the admin page:
    Fatal error: Cannot redeclare zen_href_link() (previously declared in /home/myUsername/public_html/shop/admin/includes/functions/html_output.php:28) in /home/myusername/public_html/shop/admin/includes/functions/extra_functions/html_output.php on line 31
    line 31 in functions/html_output is
    if ($connection == 'NONSSL') {
    Any ideas on what I should do?
    Mar 2011
    Hey!
    I have very similar problem as the other people had in this thred.
    When I try to load the admin login page I get this error
    Warning: require(DIR_FS_CATALOG_LANGUAGESenglish/meta_tags.php) [function.require]: failed to open stream: No such file or directory in /home/deborah/public_html/hallintaDeborah1999/includes/languages/english.php on line 50
    Fatal error: require() [function.require]: Failed opening required 'DIR_FS_CATALOG_LANGUAGESenglish/meta_tags.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/deborah/public_html/hallintaDeborah1999/includes/languages/english.php on line 50
    I have added to admin/includes/configure.php deffinition for LANGUAGES but the I still have the same problem. Can someone see whats wrong? (admin is actually hallintaDeborah1999)
    here is part of the configure.php
    define('DIR_WS_PHPBB', '/');
    That looks like the configure.php file for the Catalog rather than the Admin ...
    Check that you have not mixed up the two files ...
    Mar 2011
    Hey!
    Thank you for spotting that mistake I had mixed up those two configuration files. I corrected that but now I get only this when I'm trying to login:
    /home/deborah/public_html/includes/languages/english//meta_tags.php
    Looks like you may still have errors in the:
    /your_secret_admin_dir/includes/configure.php
    You are showing double // in that ...
    If you can post, from the server, without your secret admin directory and database password the file:
    we could look at it and see if we spot anything ...
    Mar 2011
    Hey!
    I reinstalled and I got rid of the problem, but I couldn't copy all files back (I didn't try to overwrite two configure files). Otherwise the problem came back. When tried to ovewrite admin/includes/languages folder the problem came back. So maybe the problem is there. Here is stilll my admin/includes configure file
    * @package Configuration Settings circa 1.3.9
    * @copyright Copyright 2003-2009 Zen Cart Development Team
    * File Built by zc_install on 2011-03-20 04:24:16
    /*************** NOTE: This file is similar, but DIFFERENT from the "store" version of configure.php. ***********/
    // Main webserver: eg-http://www.your_domain.com -
    // HTTP_CATALOG_SERVER is your Main webserver: eg-http://www.your_domain.com
    // HTTPS_CATALOG_SERVER is your Secure webserver: eg-https://www.your_domain.com
    * If you desire your *entire* admin to be SSL-protected, make sure you use a "https:" URL for all 4 of the following:
    define('HTTP_SERVER', 'http://www.hidden.com');
    define('HTTPS_SERVER', 'http://www.hidden.com');
    define('HTTP_CATALOG_SERVER', 'http://www.hidden.com');
    define('HTTPS_CATALOG_SERVER', 'https://www.hidden.com');
    define('DIR_WS_ADMIN', '/hidden/');
    define('DIR_WS_HTTPS_ADMIN', '/hidden/');
    define('DIR_FS_ADMIN', '/home/deborah/public_html/hidden/');
    define('DIR_FS_CATALOG', '/home/deborah/public_html/');
    define('DB_TYPE', 'mysql');
    define('DB_PREFIX', 'zen_');
    define('DB_SERVER_USERNAME', 'hidden');
    define('DB_SERVER_PASSWORD', 'hidden');
    define('DB_DATABASE', 'hidden');
    define('USE_PCONNECT', 'false');
    define('STORE_SESSIONS', 'db');
    // for STORE_SESSIONS, use 'db' for best support, or '' for file-based storage
    define('DIR_FS_SQL_CACHE', '/home/deborah/public_html/cache');
    // EOF
  7. #17
    What new debug logs are created in the:
    /cache
    directory now?
  8. #18
    Mar 2011
    There doesn't come anything new when I copy old admin/includes/language folder over new ones. Admin login just gaves the same /home/deborah/public_html/includes/languages/english//meta_tags.php
    I quess I can go around this by reinstalling languages.
    This is error I found from the log. But I think it is because I reinstalled without owerwriting the language folder.
    [20-Mar-2011 05:05:35] PHP Warning: include_once(includes/languages/french.php) [<a href='function.include-once'>function.include-once</a>]: failed to open stream: No such file or directory in /home/hidden/public_html/includes/init_includes/init_templates.php on line 72
    [20-Mar-2011 05:05:35] PHP Warning: include_once() [<a href='function.include'>function.include</a>]: Failed opening 'includes/languages/french.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/hidden/public_html/includes/init_includes/init_templates.php on line 72
    [20-Mar-2011 05:05:35] PHP Warning: require(includes/languages/french/html_includes/define_main_page.php) [<a href='function.require'>function.require</a>]: failed to open stream: No such file or directory in /home/hidden/public_html/includes/templates/theme197/templates/tpl_index_default.php on line 45
    [20-Mar-2011 05:05:35] PHP Fatal error: require() [<a href='function.require'>function.require</a>]: Failed opening required 'includes/languages/french/html_includes/define_main_page.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/hidden/public_html/includes/templates/theme197/templates/tpl_index_default.php on line 45
  1. Cannot access Admin login page after several attempts and FAQ suggestions, HELP!
    By jnb41578 in forum Installing on a Linux/Unix Server
    Last Post: 6 Jul 2011, 02:57 AM
  2. Help??? Cannot login to admin
    By arteklektrika in forum Templates, Stylesheets, Page Layout
    Last Post: 5 Jul 2009, 12:29 AM
  3. cannot login please help
    By amopro in forum Basic Configuration
    Last Post: 24 Jul 2007, 05:02 AM
  4. HELP! Cannot Admin Login
    By nextebizguy in forum General Questions
    Last Post: 10 Sep 2006, 06:12 AM
