When I try to run the fix_cache.key.php I get the following messages on my browsers. (tried in IE and FF)
FF:
"Content Encoding Error
The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression.
The page you are trying to view cannot be shown because it uses an invalid or unsupported form of compression."
IE:
"Internet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
There might be a typing error in the address."
there is no problem with the internet connection or typing.
Any ideas?
This is not the first time I use this tool for my web sites. It is where the index.php is.
Erez
