Results 1 to 7 of 7
    Apr 2006
    Homebase: Spokane, WA
    help question Problem with Define Pages Editor
    Hello all!
    Well, I have used Zen for a few years now and have multiple sites under Zen. I am working on a new one now and am having some problems....
    I have been working on adding the products fist, then do all the other config work on the sites and it has worked well for me. Yesterday when I logged into the site I thought it was kind of strange as the font had reduced significantly, didn't think too much of it so logged in and the rest was smaller too but continued to work. I had set the Define Pages Editor to HTMLarea as I was adding text to products that required linking, and all was fine. This morning I logged it (still smaller font), went to change from PlainText to HTMLarea and it won't accept the change. Additionally, when I try to edit a page from the Define page, it won't load it either. I am pretty good with quite a few issues with Zen, but this one has me. I am using 1.3.8a and the site is http://vietnampatches.com/zencart
    I hope you can help as I feel I have hit the wall on this one
    Thanks for ALL YOU GUYS DO! IT IS APPRECIATED!
    Rod
    Visit my Zen Site: Hat n' Patch
    Oct 2008
    Default Re: Problem with Define Pages Editor
    If you had a customized template on your other store then you load this one with the classic which is not edited in anyway could be the reason why you see smaller text.
    Apr 2006
    Thanks, but this started happening in the middle of loading products with a FRESH install. It worked fine and I have made no changes to the template (yet).
    Rod
    Apr 2006
    Also another 'issue' I have just discovered is when I use any of the dropdown changes (i.e. change from Plain Text to HTMLarea or page jumps in products (on page 1 and try to use the dropdown to jump to page 5) nothing happens and it just sits there.
    More head banging I guess
    Rod
    Dec 2005
    Cincinnati Ohio
    Did you check with your host and see if they are having issues with the servers or network?
    You can also run this script http://www.zen-cart.com/index.php?ma...roducts_id=860
    To be sure nothing is wrong with your files, however this only reads the customer side but worth the shot.
    Hanging usually means file related or server related I would investigate both.
    PCI Certified Web Hosting - ControlScan, Security Metrics (Platinum Partner), McAfee, TrustKeeper
    Business Class Web Hosting - Linux and cPanel Powered
    Apr 2006
    Thanks Knuckle, I will run it and see if anything comes out. I do have to question the 'server issue' though as I have other sites that are 1.3.8a running on the same server and IP with no problem. What controls the activation of a dropdown menu choice?
    Rod
    Dec 2005
    Cincinnati Ohio
    Quote Originally Posted by rod44 View Post
    Category drop down menu you have to integrate a dropdown menu or use one of the mods provided in the downloads section of this website.
    Like this one for example http://www.zen-cart.com/index.php?ma...roducts_id=479
    Zencart itself does not have a out of the box dropdown
  1. [Duplicate] Problem with Define Pages Editor
    By grabnsnap in forum Bug Reports
    Last Post: 7 Dec 2010, 07:27 AM
  2. Problem with Define Pages Editor
    By burgundy in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Jul 2009, 06:14 PM
  3. problem with Define Pages Editor
    By pglenn in forum General Questions
    Last Post: 20 Mar 2009, 03:56 AM
  4. Problem with define pages editor and Bullet Points
    By ksmglobal in forum Basic Configuration
    Last Post: 29 Jan 2008, 02:53 PM
  5. Problem with define pages editor
    By Phid in forum General Questions
    Last Post: 1 Jul 2006, 03:33 AM
