Results 1 to 9 of 9
    Sep 2008
    Default Item spacing problem
    I recently put a discontinued item on sale. No problems there. Creating the sale was easy and straight forward. My issue comes with the way the two text lines that SaleMaker adds to the item effect the grid spacing. Please check the following page to see what I mean:
    https://runnersdenaz.com/store/index...dex&cPath=8_10
    The addition of the extra lines ("Sale: $74.95" and "Save: 21% off") throws off the spacing for the rest of the page. There is now a big space below the item in question (Asics 2130) that makes everything look haphazard and thrown together. Definitely not the look I was going for. The link above is to the "men's stability" page. I'm having the same problem on the correlating women's page as well.
    I would like everything to lay out like it was before (for an example please see: https://runnersdenaz.com/store/index...ex&cPath=12_15) in a nice even grid while still maintaining the sale info.
    Any ideas?
    Sep 2008
    Default Re: Item spacing problem
    I just encountered another problem while trying to fix the first problem...
    I thought that setting the sale item as a "Special" instead of using SaleMaker, I might end up with a different layout. I have never used the Specials feature, so I clicked on Admin/Catalog/Specials, and...
    Nothing happens. I end up staying on the main Admin screen. Is there something in the background I need to do in order to enable the Specials feature?
    I am using the most recent version of Zen Cart.
    Sep 2008
    Everything I can think of has been reinstalled and updated. I am still unable to find a solution for the two issues listed above. Any assistance or advice that anyone can give would be greatly appreciated. Thanks in advance.
    Sep 2008
    I figured out the "Specials" problem. While adapting our template to our existing site, some of the changes we made disabled the specials function. No worries on that end. I still haven't found a solution to my initial problem regarding the spacing. If anyone can offer any advice, it will be greatly appreciated.
    Jun 2007
    Shropshire UK
    Go to:
    Configuration/All Listing
    I think this may be what you are looking for ?
    Display Product Name 2101
    Display Product Model 2201
    Display Product Manufacturer Name 2302
    Display Product Price 2402
    Display Product Weight 2502
    Do you want to display the Product Weight?
    0= off
    1st digit Left or Right
    2nd and 3rd digit Sort Order
    4th digit number of breaks after
    Might be worth a look there ?
    Sep 2008
    I messed with the settings, and nothing happens. I've checked IE and FF, and no matter what I set the 4th digit to, the layout remains identical... I have no idea why. Anyone else have any ideas?
    Jun 2007
    Shropshire UK
    Quote Originally Posted by RunnersDen View Post
    Pity about that - I guess the fact is that the "Sale Item"
    Sale: $74.95
    Save: 21% off
    is taking the extra Space - so the only way I imagine might work is to take the Sale items out of the "Men's Stability" category - and put them in a "Sale category" of their own - all products in there would then have the 2 extra lines of text - unless there is a switch some where to only display sale items on a separate (dedicated sale item) page ?
    Ah well - worth a try....?
    Sep 2008
    I have been considering doing that. The only problem is that I would need to remove the Manufacturer and the Model information from them or they would still show up if a customer uses the drop down menus to filter the products. In the end, I am going to have to choose the lesser of the evils...
    Leave things how they are and be irritated every time I look at it, or...
    Create the sale category, and lose the ability to have our customers see the sale when they search by manufacturer or model...
    Jun 2007
    Shropshire UK
    Lesser of 2 evils....?
    I know what you mean - I get real annoyed at things I cannot control like that - my wife thinks it's sometimes a failing - thinks it better to let it go and get on with more important problems - I see it as "attention to detail" - but see her point - and I guess as time goes by - you maybe have to "let it go" - (She does some running too BTW - although that is not gonna help with this problem )
  1. Need help with the spacing of Item Listing
    By comicmegastore in forum Templates, Stylesheets, Page Layout
    Last Post: 24 Jun 2010, 08:50 AM
  2. Item name spacing
    By chris1122 in forum Templates, Stylesheets, Page Layout
    Last Post: 12 Aug 2008, 10:35 AM
  3. Spacing Problem
    By bpditty in forum Templates, Stylesheets, Page Layout
    Last Post: 22 Jan 2008, 04:02 AM
  4. item row display- spacing issue
    By product247 in forum Templates, Stylesheets, Page Layout
    Last Post: 15 Oct 2007, 04:34 AM
  5. Multiple Images For 1 Item / Spacing The Description
    By hudda in forum Templates, Stylesheets, Page Layout
    Last Post: 27 Jun 2007, 10:02 AM
