Hi!
I have taken over a website and need to update it for a client. Unfortunately and I know this is my fault, I'm still not good at CSS I'm afraid. (Not Zencart just a website, although the cart portion is ZC)
Anyway at the moment it is 2 columns, left and the main body. I want to add a 3rd right hand column (like the LHC).
Each page uses <?php require_once('inc/bottom.php'); ?>
to insert the bottom footer as well as the LHC.
bottom.php contains:
<div class="sidebar"> <p align="center"><img src="pageimg/image.jpg" border="0" /></a></p></div>
which makes up the LHC sidebar.
In the CSS the class `sidebar' says:
.sidebar { width:250px; float:left; margin:0 20px; }
So I want this sidebar on the right as well (different content etc).
I tried to add .rsidebar and change float:left to float:right but as I said that probably meant nothing as all it did was repeat the sidebar 2x on the left.
Is there a CSS class I can use that will make it appear on the RHS of the page and if so what?
Then I could just edit the bottom.php file and be done!
Thanks if anyone can help!
Ernie
