    Jul 2008
    Default Product Reviews Layout... Help Needed!
    If you have a look at this link you will notice that the header bar has gone all funny is it possible to change this?
    Feb 2008
    Default Re: Product Reviews Layout... Help Needed!
    that is due to the image you are using in the header. you will have to set the padding on the text so both lines will fit in the header. or center the text as a whole not just the first line.
    I am sure someone else knows exactly how to fix it but I tried.
    Apr 2006
    London, UK
    In your stylesheet, find the definitions for #reviewsInfoDefaultHeading (around about line 110). Remove the bottom padding and reduce the top padding to 5 or 6px.
    Jul 2008
    Quote Originally Posted by kuroi View Post
    Thank you for your replies that has worked perfect thank you!
  1. Product Reviews - page layout source?
    By dedicationgraphics in forum Templates, Stylesheets, Page Layout
    Last Post: 28 Jun 2012, 02:48 AM
  2. Replies: 5
    Last Post: 17 Feb 2010, 05:13 PM
  3. category / product layout help needed
    By boogily in forum Setting Up Categories, Products, Attributes
    Last Post: 2 Nov 2009, 04:14 AM
  4. Help needed with layout
    By mike1234 in forum Basic Configuration
    Last Post: 7 Feb 2009, 07:23 PM
  5. PHP pro coders help needed, product layout
    By waghelak in forum Templates, Stylesheets, Page Layout
    Last Post: 17 Oct 2007, 01:13 PM
