Hi Everybody, This is second time that I write same thing but I still couldn't Sold this problem Out.
When I try to add any new product to any Category I get this Error :
"Not Found
The requested URL /admin/CatagoryIMG.php was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.41 Server at www.ozcartridge.com.au Port 80"
This Error from Admin page If you try to view from catalog it says :
"Page Not Found
Custom 404 Error Page with Site Map Sample Text ...
Page Not Fount. If tehere is anyproblem with website pls Contact with us. Thanks OzCartridge Support Team ([email protected]) "
I think CatagoryIMG.php mistahe with this I need to find why this php folder coming up I didn't change anything in index.php Folder.
This problem started last Night. Yesterday I just Added Google Bar to my side bar also I did some small changes as image sizes from admin etc. But I can't remember if I changed anything else.
Also when i Tryed to search in Devalopers tool kit for CatagoryIMG.php nothing coming up.
I have to Fix this problem as soon as i can.
Thanks for attention Guys.
The website is www.ozcartridge.com.au
Guys I tryed something else maybe it can help us more. I had a backup of Admin and Includes Folders 4 days ago and in that time was working well. I deleted Admin and Includes folders from side and I directly put the old ones and I can say There was same problem happening
Basically I can say nothing to do into Admin and Includes Folders.I don;t know maybe not
Also There is the Error codes from error_log :
[16-Dec-2008 19:16:39] PHP Warning: require(includes/application_top.php) [<a href='function.require'>function.require</a>]: failed to open stream: No such file or directory in /home/emrekusb/public_html/ozcartridge.com.au/index.php on line 26
[16-Dec-2008 19:16:39] PHP Fatal error: require() [<a href='function.require'>function.require</a>]: Failed opening required 'includes/application_top.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/emrekusb/public_html/ozcartridge.com.au/index.php on line 26
