Results 1 to 10 of 15
    Dec 2008
    Default Using HostGator and Shared SSL, Secure and Unsecure Items?
    Hi All,
    believe me , I have searched every thread on this forum before wasting anyone's time posting this question. I couldn't find an answer to my specific problem, so I'm asking here.
    I am using hostgator, and hosting a site on my reseller account (www.criticalthinkersonline.net). I am using their shared SSL cert. I changed both config files to point to my shared SSL secure page (https://sonata.websitewelcome.com/~critical/) and set use SSL to true.
    Zen Cart properly switches over to the secure pages when necessary (on the shopping cart, my account pages, and when purchasing), but in FF I get the lock with a slash through it, and in IE the popup saying there is secure and non-secure items.
    You can look at the source of the secured pages, and see that there are tons of http://critical... links, but these are all generated by Zen Cart. The only thing I have changed on this template (one called Orange) are colors in the css file, and changed the header by creating a new image and overwriting the existing one. In the .css it point to the relative location of the file. However, if you click on view image (on a secured page) you see that its pointing to an http: referenced image. I tried specifying the secured link to the header image in the .css, but it still did not change the security warning.
    Why are all these links nonsecure, even on the secured pages? I assume zen cart should switch over to using secured versions when necessary, and its showing nonsecured URLS in the secured pages, and thats why I am getting this warning. In IE if I tell it NOT to show unsecured items, it basically strips everyhting but text out of the page.
    sooo....any ideas on whats going on here?
    Jun 2003
    Default Re: Using HostGator and Shared SSL, Secure and Unsecure Items?
    Please post your includes/configure.php minus your password
    N of San Antonio TX
    You have several links in your source that point to http://.... versus ../images/whatever.
    With the http:// links on a secure page, you'll always get a broken lock.
    check http://www.motive.co.nz/glossary/linking.php to see better ways to do it.
    A little help with colors.
    Dec 2008
    I have read those tutorials and I have not manually editing anything that points to a http: location. Those images are all picutres of products uploaded through zen cart. Wouldn't it switch those over to use the secure URL when you hit a secure page?
    The only image I have edited is the logo, which is a relative link in the .css file for the template.
    /includes/configure.php below:
     * dist-configure.php
     * @copyright Copyright 2003-2007 Zen Cart Development Team
     * @version $Id: dist-configure.php 6329 2007-05-16 15:36:56Z drbyte $
     * @private
    // HTTP_SERVER is your Main webserver: eg-http://www.yourdomain.com
    // HTTPS_SERVER is your Secure webserver: eg-https://www.yourdomain.com
    define('HTTP_SERVER', 'http://criticalthinkersonline.net');
    define('HTTPS_SERVER', 'https://sonata.websitewelcome.com/~critical');
    define('ENABLE_SSL', 'true');
    define('DIR_WS_PHPBB', '/phpBB2/');
    define('DIR_FS_CATALOG', '/home/critical/public_html/');
    //REMOVED DB CONNECTION INFO
    // For SQL_CACHE_METHOD, you can select from:  none, database, or file
    // ie: /path/to/your/webspace/public_html/zen/cache   -- leave no trailing slash
    define('DIR_FS_SQL_CACHE', '/home/critical/public_html/cache/');
    Jun 2003
    What if you add the www to:
    The following IMG tags are not generated by a clean Zen Cart install without addons. (Nor the table in which they appear on your site). Zen Cart always produces relative paths, in order to avoid these security issues. Instead you must have hard-coded the full URL into your template files somewhere. The FAQ article still applies, and has nothing to do with HostGator.
    <img src="http://www.criticalthinkersonline.net/hosted/storefront.jpg">
    </center>
    <br>
    <h1><span style="color: rgb(0, 0, 102);"><center>Please proceed through the doors of Science, Math, Language Arts, Social Studies, Spanish, or Reading.</center></span></h1>
    <br>
    <table width="100%" border="0">
      <tr>
        <td><div align="center"><strong><span class="style1">Science</span></strong></div></td>
        <td><div align="center"><strong><span class="style1">Math</span></strong></div></td>
        <td><div align="center"><strong><span class="style1">Language Arts</span></strong></div></td>
      </tr>
      <tr>
        <td><div align="center"><a href="http://criticalthinkersonline.net/index.php?main_page=index&cPath=5"><img src="http://www.criticalthinkersonline.net/hosted/icons/Door.png" width="128" height="128" border="0" /></a></div></td>
        <td><div align="center"><a href="http://criticalthinkersonline.net/index.php?main_page=index&cPath=4"><img src="http://www.criticalthinkersonline.net/hosted/icons/Door.png" alt="" width="128" height="128" border="0" /></a></div></td>
        <td><div align="center"><a href="http://criticalthinkersonline.net/index.php?main_page=index&cPath=1"><img src="http://www.criticalthinkersonline.net/hosted/icons/Door.png" alt="" width="128" height="128" border="0" /></a></div></td>
      </tr>
      <tr>
        <td><div align="center"><strong><span class="style1">Social Studies</span></strong></div></td>
        <td><div align="center"><strong><span class="style1">Spanish</span></strong></div></td>
        <td><div align="center"><strong>Reading</strong></div></td>
      </tr>
      <tr>
        <td><div align="center"><a href="http://criticalthinkersonline.net/index.php?main_page=index&cPath=6"><img src="http://www.criticalthinkersonline.net/hosted/icons/Door.png" alt="" width="128" height="128" border="0" /></a></div></td>
        <td><div align="center"><a href="http://criticalthinkersonline.net/index.php?main_page=index&cPath=7"><img src="http://www.criticalthinkersonline.net/hosted/icons/Door.png" alt="" width="128" height="128" border="0" /></a></div></td>
        <td><div align="center"><a href="http://criticalthinkersonline.net/index.php?http://criticalthinkersonline.net/index.php?main_page=index&cPath=3"><img src="http://www.criticalthinkersonline.net/hosted/icons/Door.png" alt="" width="128" height="128" border="0" /></a></div></td>
    Dec 2008
    I fixed all those, problem still remains. I left those in because that table is only shown on the main index page (define_main_page.php). I changed them all to relative links now, but it didnt change anything. Nothing in define_main_page.php is displayed on any secure page.
    If i just click on "Log In" I'm taken to the login page, which shows the unsecured lock image in firefox. Viewing the source, I see many links that are http - mainly for that horizontal category nav bar.
     <td id="navColumnOne" class="columnLeft" style="width: 150px">
    <div id="navColumnOneWrapper" style="width: 150px"><!--// bof: categories //-->
    <div class="leftBoxContainer" id="categories" style="width: 150px">
    <h3 class="leftBoxHeading" id="categoriesHeading">Categories</h3>
    <div id="categoriesContent" class="sideBoxContent">
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=7&amp;zenid=3cd2fc85a46934d10355449772baef5c">Bilingual Education-&gt;</a>&nbsp;(81)<br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=110&amp;zenid=3cd2fc85a46934d10355449772baef5c">Children's Books-&gt;</a>&nbsp;(74)<br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=54&amp;zenid=3cd2fc85a46934d10355449772baef5c">Classroom Furniture</a><br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=53&amp;zenid=3cd2fc85a46934d10355449772baef5c">Early Childhood/Preschool-&gt;</a>&nbsp;(53)<br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=1&amp;zenid=3cd2fc85a46934d10355449772baef5c">Language Arts-&gt;</a>&nbsp;(333)<br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=3&amp;zenid=3cd2fc85a46934d10355449772baef5c">Leveled Readers-&gt;</a>&nbsp;(431)<br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=52&amp;zenid=3cd2fc85a46934d10355449772baef5c">Manipulatives-&gt;</a>&nbsp;(22)<br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=4&amp;zenid=3cd2fc85a46934d10355449772baef5c">Mathematics-&gt;</a>&nbsp;(106)<br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=55&amp;zenid=3cd2fc85a46934d10355449772baef5c">Professional Books</a><br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=5&amp;zenid=3cd2fc85a46934d10355449772baef5c">Science-&gt;</a>&nbsp;(101)<br />
    <a class="category-top" href="http://www.criticalthinkersonline.net/index.php?main_page=index&amp;cPath=6&amp;zenid=3cd2fc85a46934d10355449772baef5c">Social Studies-&gt;</a>&nbsp;(87)<br />
    <hr id="catBoxDivider" />
    <a class="category-links" href="http://www.criticalthinkersonline.net/index.php?main_page=products_new&amp;zenid=3cd2fc85a46934d10355449772baef5c">New Products ...</a><br />
    <a class="category-links" href="http://www.criticalthinkersonline.net/index.php?main_page=products_all&amp;zenid=3cd2fc85a46934d10355449772baef5c">All Products ...</a>
    </div></div>
    <!--// eof: categories //-->
    <!--// bof: information //-->
    <div class="leftBoxContainer" id="information" style="width: 150px">
    <h3 class="leftBoxHeading" id="informationHeading">Information</h3>
    <div id="informationContent" class="sideBoxContent">
    <ul style="margin: 0; padding: 0; list-style-type: none;">
    <li><a href="http://www.criticalthinkersonline.net/index.php?main_page=shippinginfo&amp;zenid=3cd2fc85a46934d10355449772baef5c">Shipping &amp; Returns</a></li>
    <li><a href="http://www.criticalthinkersonline.net/index.php?main_page=privacy&amp;zenid=3cd2fc85a46934d10355449772baef5c">Privacy Notice</a></li>
    <li><a href="http://www.criticalthinkersonline.net/index.php?main_page=conditions&amp;zenid=3cd2fc85a46934d10355449772baef5c">Conditions of Use</a></li>
    <li><a href="http://www.criticalthinkersonline.net/index.php?main_page=contact_us&amp;zenid=3cd2fc85a46934d10355449772baef5c">Contact Us</a></li>
    <li><a href="http://www.criticalthinkersonline.net/index.php?main_page=site_map&amp;zenid=3cd2fc85a46934d10355449772baef5c">Site Map</a></li>
    <li><a href="http://www.criticalthinkersonline.net/index.php?main_page=gv_faq&amp;zenid=3cd2fc85a46934d10355449772baef5c">Gift Certificate FAQ</a></li>
    <li><a href="http://www.criticalthinkersonline.net/index.php?main_page=discount_coupon&amp;zenid=3cd2fc85a46934d10355449772baef5c">Discount Coupons</a></li>
    <li><a href="http://www.criticalthinkersonline.net/index.php?main_page=unsubscribe&amp;zenid=3cd2fc85a46934d10355449772baef5c">Newsletter Unsubscribe</a></li>
    </ul>
    </div></div>
    <!--// eof: information //-->
    but these links are all generated by zen cart. Even the home link and copyright link at the bottom (generated by zen cart) are to the nonsecured url.
    Oops. I was certain that I took that content from your login page. Apparently I did not.
    Your real problem is this:
    On a Secure page, you're still getting a base href URL for non-secure content:
    <base href="http://www.criticalthinkersonline.net/" />
    Ideally that should switch to the URL for your secure site, ie:
    <base href="https://sonata.websitewelcome.com/~critical/" />
    There are a couple causes for the automatic switching to not occur properly:
    1) ENABLE_SSL is not set to 'true'. (Yours must be or your login pages wouldn't be switching into SSL mode, so that's not the problem in your case.)
    2) The SSL certificate is not actually fully valid or secure
    3) The many industry-standard detection options available to determine whether the page is actually "secure" are not working on your server. This is VERY common on Network Solutions and Fasthosts hosting plans. But I've not seen that problem on HostGator normally.
    If you care to figure out what technical issue is preventing proper detection, here is the logic that determines whether the page has been delivered in SSL mode:
    $request_type = ((isset($_SERVER['HTTPS']) && strtolower($_SERVER['HTTPS']) == 'on')
                     || (isset($_SERVER['HTTPS']) && $_SERVER['HTTPS'] == '1')
                     || (isset($_SERVER['HTTP_X_FORWARDED_BY']) && strstr(strtoupper($_SERVER['HTTP_X_FORWARDED_BY']),'SSL'))
                     || (isset($_SERVER['HTTP_X_FORWARDED_HOST']) &&  strstr(strtoupper($_SERVER['HTTP_X_FORWARDED_HOST']),'SSL'))
                     || (isset($_SERVER['SCRIPT_URI']) && strtolower(substr($_SERVER['SCRIPT_URI'], 0, 6)) == 'https:')
                     || (isset($_SERVER['SERVER_PORT']) && $_SERVER['SERVER_PORT'] == '443' )   )  ? 'SSL' : 'NONSSL';
    You may have to work with their tech support to determine why none of these common modes for SSL operation can be detected on the server you've been assigned to.
    Dec 2007
    Payson, AZ
    Not sure if this will help you, but when I first open my site I used HostGator shared SSL. I couldn't get it to work at all, after asking them why, they told me that the shared cert would not work with php5. Didn't make much seance to me, but what I did I had set my .htaccess file up with,
    AddHandler application/x-httpd-php5 .php
    Changing it to;
    AddHandler application/x-httpd-php .php
    the shared SSL work fine after that change.
    This was before they upgraded the servers to php5 and I had my own cert installed. I also noticed that even after upgrading to php5 and changing the Addhandler to php5, they commented it out. They may still be having issues with php5 and shared certs.
    Dave
    Always forward thinking... Lost my mind!
  1. SSL secure and non-secure items
    By angel17846 in forum Basic Configuration
    Last Post: 20 Nov 2013, 06:57 PM
  2. Replies: 1
    Last Post: 7 May 2009, 09:06 AM
  3. Hostgator -- Shared SSL issue
    By mnboater in forum Basic Configuration
    Last Post: 10 Sep 2008, 03:26 PM
  4. Secure and unsecure items problem
    By authenticnz in forum General Questions
    Last Post: 19 Apr 2008, 10:38 PM
