I'm having a big problem here, i'm trying to use a mod called tabbed products pro.
I have to require a custom file called tags.php in my product_info_display.php file.
http://www.shoppingitonline.com/inde...
You can see my problem there. Those [[tags]] should be showing up as links to popups, not the way they are. I believe its a problem with the require that tabbed product pro uses. When I don't have:
//BOF :: Tabbed Products Pro ::
require(DIR_WS_MODULES . 'tabbed_products_pro.php');
//EOF :: Tabbed Products Pro ::
in my code, my tags work fine. Would anyone know how to work around this? I must include this code:
require_once('tags.php');
or my tags will not work. I have a feeling that this require is overwriting the tags one or something. Any help would be very appreciated! Thanks!
