Results 1 to 2 of 2
    May 2004
    Idea or Suggestion Using application_top.php for multi store solution?
    I've fiddled off n on with zencart for years, I know a multi store solution has been a much anticipated feature.
    I stumbled across some code & wanted some opinions on if it could be used to suit a particular need.
    My particular need is to have multiple stores managed by individual admins.
    However I dont want to install the filesystem (10+mb) for each store. it also becomes a chore to individually upgrade each store when new versions arrive.
    With the included code below (found in application_top.php) would it be possible to have one filesystem install and call one of a variety of properly populated databases?
     Set the local configuration parameters mainly for developers
    if (
    file_exists('includes/local/configure.php')) {
       * load any local(user created) configure file.
    include('includes/local/configure.php');
    If im not mistaken, this function allows zencart to connect to an alternate config file and therefore a different database and template (thus making the single install dynamic in content)
    anyone have any ideas on how to make the above code a variable that can be called via a cookie, variable, session, token or URL string?
    Moderators, if there is a more appropriate forum for this topic please move it to the appropriate location.
    May 2004
    Default Re: Using application_top.php for multi store solution?
    Something like this?
     * Set the local configuration parameters - mainly for developers
    if (file_exists('includes/local/configure.php')) {
    else{
    // load dynamic config file
    include('includes/local/[i]variableconfigfile[/i]')
    variableconfigfile being config2.php, config3.php etc.
  1. usa ePay solution for PHP 5.3?
    By gotlogos in forum Addon Payment Modules
    Last Post: 1 Dec 2010, 01:54 AM
  2. Multi User, Multi Store on same domain
    By lolzita in forum General Questions
    Last Post: 7 Dec 2009, 04:02 PM
  3. Using .php code from another cart for multi-shipping?
    By foodstr2 in forum General Questions
    Last Post: 12 Sep 2008, 02:07 PM
