Re: Need help with Manufacturer SideBox
To display without the dropdown format, go to Admin>Configuration>Maximum Values>Manufacturers List - Scroll Box Size/Style
A 0 or 1 there sets the style as dropdown.
To add a banner, you'll need to do some code modifications to includes/modules/sideboxes/manufacturers.php and/or
includes/templates/template_default/sideboxes/tpl_manufacturers_select.php, remembering to save modified files in override folders.
Neville
An assumption is what you arrive at when you get tired of thinking...
