Help. Has anyone created a payment module for First Data Global Gateway?
That would be the built in linkpoint payment module. Linkpoint/Yourpay/First data is now First Data Global
Mike
AEIIA - Zen Cart Certified & PCI Compliant Hosting
Except for the problem the Linkpoint supports port 1129 for communication and if you are hosted with GoDaddy, they only support port 443, anyone figure out a workaround? FirstData tech refuses to help with this problem and says we have to use Webrserver instead.
You have 2 choices - move away from godaddy or use another payment service. The recommended course ... move off of godaddy, you will continue to have challenges.
I have to agree, go elsewhere for your hosting. This module works flawlessly with my host, and very easy to set up.
