My site was working fine and then I tried installing the dangling carrot add on and the right column and footer wouldn't load up so checked all files - seemed ok. Having checked on the forum I discovered other people have had similar problem but I couldnt locate how to solve the problem and have a working addon so I removed all file relating to the dangling carrot add-on. I replaced any missing files by using the full fileset.
HOWEVER, the site no longer loads up and I can't work out why.
I have run the debug error file but there are no error files in the cache folder so I must have done something wrong.
When I had deleted sufficient carrot files that my site loaded correctly I actually backed up my site with the cpanel backup system - BUT, I cannot seem to get it to restore - how long should it take?
I would be most grateful for anyones help/advice.
