Results 1 to 8 of 8
    Dec 2008
    Los Angeles, CA
    Default Easy Page problem
    Hi All,
    I created easy page and It doesn't show on my site.
    1) I created from admin>tools>EZ pages
    2) Than I went admin> conf.> EZ pages setting and I chose to display on sidebox Value 1 and EZpage display left collom and entered ID#.
    It doesn't show. Should I need to go somewhere else to turn on the EZpages?
    Jun 2005
    Cumbria, UK
    Default Re: Easy Page problem
    Make sure you are giving the correct "instructions" in EZpages Configuration.
    Where are you entering the ID number? and for what purpose?
    Additionally, an EZPage must have a sort order greater than "0" for it to appear.
    20 years a Zencart User
    Dec 2008
    Los Angeles, CA
    I create EZpage and the name is video. I enabled sidebox status at admin>tools>EZpages and sidebox order 1. when I'm going to admin>conf.>EZpages setting, I entered 1 on EZpage desplay status - left collom, but it still doesn't show on main pae.
    Jun 2005
    Cumbria, UK
    In the EZPages main console, you will see your page name, then a whole row of RED or GREEN buttons (icons).
    Make sure that the button allocated for that page, to Sidebox, is GREEN.
    Apr 2006
    Texas
    Quote Originally Posted by expensivedesign View Post
    Ex,
    Also make sure of this:
    1. admin panel/ tools/ layout boxs controller/ sideboxes/ezpages.php
    2. make sure she is turned on
    Jun 2005
    Cumbria, UK
    Quote Originally Posted by haredo View Post
    Ex,
    Absolutely... well spotted haredo!
    Sometimes we miss the wood for the trees!
    Dec 2008
    Los Angeles, CA
    Thanks It works. The reason was I didn't turned on EZpage from admin>tools>layout boxes control.
    Apr 2006
    Texas
    Ex,
    Aruuuuugggghh,
    All those pesty controls takes a while to find them all.
    Glad you are up and running....
  1. Easy Populate Problem
    By jax2 in forum All Other Contributions/Addons
    Last Post: 21 Jun 2014, 01:38 PM
  2. easy checkout db problem
    By Miff in forum All Other Contributions/Addons
    Last Post: 27 Nov 2011, 03:58 AM
  3. Fast and Easy Checkout - One Page Check out problem
    By jorsara in forum Addon Templates
    Last Post: 31 Mar 2010, 03:56 PM
  4. Easy Populate Problem
    By moejoe1976 in forum All Other Contributions/Addons
    Last Post: 29 Apr 2008, 11:03 PM
