Results 11 to 20 of 27
    Aug 2006
    UK
    Default Re: Problem with OPERA Additional Images Display
    i dont have the lightbox mod installed, so I'm guessing that adds something to additional_images.php..???
    ~Steve~
    Jan 2009
    Well, it must :-)
    Here's the line in question:
    BEFORE YOUR CHANGE:
        // List Box array generation:
    $list_box_contents[$row][$col] = array('params' => 'class="additionalImages centeredContent back"' ' ' 'style="width:' $col_width '%;"',
    'text' => "\n      " $link);
    $col ++;
        if (
    $col > (IMAGES_AUTO_ADDED -1)) {
    $col 0;
    $row ++;
    // end for loop
    // endif
    AFTER:
    $list_box_contents[$row][$col] = array('params' => 'class="additionalImages centeredContent back"' ' ' 'style="width:130px;' $col_width '%;"',
    $col ++;
        if (
    $col 0;
    $row ++;
    // end for loop
    // endif
    As you can see, the little . $col_width . '%;"', part is the only difference in that line.... here is a copy of the entire file though:
     * additional_images module
     * Prepares list of additional product images to be displayed in template
     * @package templateSystem
     * @copyright Copyright 2003-2006 Zen Cart Development Team
     * @copyright Portions Copyright 2003 osCommerce
     * @license http://www.zen-cart.com/license/2_0.txt GNU Public License V2.0
     * @version $Id: additional_images.php 5369 2006-12-23 10:55:52Z drbyte $
    if (!defined('IS_ADMIN_FLAG')) {
      die(
    'Illegal Access');
    if (!
    defined('IMAGE_ADDITIONAL_DISPLAY_LINK_EVEN_WHEN_NO_LARGE')) define('IMAGE_ADDITIONAL_DISPLAY_LINK_EVEN_WHEN_NO_LARGE','Yes');
    $images_array = array();
    if (
    $products_image != '') {
    // prepare image name
    $products_image_extension substr($products_imagestrrpos($products_image'.'));
    $products_image_base str_replace($products_image_extension''$products_image);
    // if in a subdirectory
    if (strrpos($products_image'/')) {
    $products_image_match substr($products_imagestrrpos($products_image'/')+1);
    //echo 'TEST 1: I match ' . $products_image_match . ' - ' . $file . ' -  base ' . $products_image_base . '<br>';
    $products_image_match str_replace($products_image_extension''$products_image_match) . '_';
    $products_image_base $products_image_match;
    $products_image_directory str_replace($products_image''substr($products_imagestrrpos($products_image'/')));
      if (
    $products_image_directory != '') {
    $products_image_directory DIR_WS_IMAGES str_replace($products_image_directory''$products_image) . "/";
      } else {
    $products_image_directory DIR_WS_IMAGES;
    // Check for additional matching images
    $file_extension $products_image_extension;
    $products_image_match_array = array();
      if (
    $dir = @dir($products_image_directory)) {
        while (
    $file $dir->read()) {
          if (!
    is_dir($products_image_directory $file)) {
            if (
    substr($filestrrpos($file'.')) == $file_extension) {
    //          if(preg_match("/" . $products_image_match . "/i", $file) == '1') {
    if(preg_match("/" $products_image_base "/i"$file) == '1') {
                if (
    $file != $products_image) {
                  if (
    $products_image_base str_replace($products_image_base''$file) == $file) {
    //  echo 'I AM A MATCH ' . $file . '<br>';
    $images_array[] = $file;
                  } else {
    //  echo 'I AM NOT A MATCH ' . $file . '<br>';
        if (
    sizeof($images_array)) {
    sort($images_array);
    $dir->close();
    // Build output based on images found
    $num_images sizeof($images_array);
    $list_box_contents '';
    $title '';
    if (
    $num_images) {
    $row 0;
    $col 0;
      if (
    $num_images IMAGES_AUTO_ADDED || IMAGES_AUTO_ADDED == ) {
    $col_width floor(100/$num_images);
      } else {
    $col_width floor(100/IMAGES_AUTO_ADDED);
      for (
    $i=0$n=$num_images$i<$n$i++) {
    $file $images_array[$i];
    $products_image_large str_replace(DIR_WS_IMAGESDIR_WS_IMAGES 'large/'$products_image_directory) . str_replace($products_image_extension''$file) . IMAGE_SUFFIX_LARGE $products_image_extension;
    $flag_has_large true;//file_exists($products_image_large);
    $products_image_large = ($flag_has_large $products_image_large $products_image_directory $file);
    $flag_display_large = (IMAGE_ADDITIONAL_DISPLAY_LINK_EVEN_WHEN_NO_LARGE == 'Yes' || $flag_has_large);
    $base_image $products_image_directory $file;
    $thumb_slashes zen_image($base_imageaddslashes($products_name), SMALL_IMAGE_WIDTHSMALL_IMAGE_HEIGHT);
    // remove additional single quotes from image attributes (important!)
    $thumb_slashes preg_replace("/([^\\\\])'/"'$1\\\''$thumb_slashes);
    $thumb_regular zen_image($base_image$products_nameSMALL_IMAGE_WIDTHSMALL_IMAGE_HEIGHT);
    $large_link zen_href_link(FILENAME_POPUP_IMAGE_ADDITIONAL'pID=' $_GET['products_id'] . '&pic=' $i '&products_image_large_additional=' $products_image_large);
    // Link Preparation:
    $script_link '<script language="javascript" type="text/javascript"><!--' "\n" 'document.write(\'' . ($flag_display_large '<a href="javascript:popupWindow(\\\'' $large_link '\\\')">' $thumb_slashes '<br />' TEXT_CLICK_TO_ENLARGE '</a>' $thumb_slashes) . '\');' "\n" '//--></script>';
    $noscript_link '<noscript>' . ($flag_display_large '<a href="' zen_href_link(FILENAME_POPUP_IMAGE_ADDITIONAL'pID=' $_GET['products_id'] . '&pic=' $i '&products_image_large_additional=' $products_image_large) . '" target="_blank">' $thumb_regular '<br /><span class="imgLinkAdditional">' TEXT_CLICK_TO_ENLARGE '</span></a>' $thumb_regular ) . '</noscript>';
    //      $alternate_link = '<a href="' . $products_image_large . '" onclick="javascript:popupWindow(\''. $large_link . '\') return false;" title="' . $products_name . '" target="_blank">' . $thumb_regular . '<br />' . TEXT_CLICK_TO_ENLARGE . '</a>';
    $link $script_link "\n      " $noscript_link;
    //      $link = $alternate_link;
    $col ++;
        if (
    $col 0;
    $row ++;
    // end for loop
    // endif
    Aug 2006
    UK
    You have the following PHP;
    . 'style="width:130px;' . $col_width . '%;"',
    try
    . 'style="width:130px;" ',
    If you leave that code in your page, I'll go take a look...
    ~Steve~
    Aug 2006
    UK
    I believe you may be editing the wrong file. I downloaded the lightbox module, and the additional_images.php file is different from the one you have posted...
    ~Steve~
    Jan 2009
    OK, I've left that in, but still Zen Lightbox disabled.... Maybe you can pick up on the problem from the page code?
    Aug 2006
    UK
    Definately the wrong file, there is a whole lot of "Zen Lightbox" code missing from the php file you posted... or maybe I should say, the right file, but the wrong code inside it.... check that you have not overwritten the customised additional_images.php file that comes with the lightbox module.
    ~Steve~
  7. #17
    Jan 2009
    That's odd... I downloaded mines from here:
    http://www.zen-cart.com/index.php?ma...roducts_id=273
    Is this the same one you got?
    I just downloaded it again, uploaded the newly downloaded version with your width changes at the bottom, just to see if it was that.. Still the same though..
    Take another look and see if it's the same file.
  8. #18
    Jan 2009
    Maybe you can post the code from your file and I'll upload that?
  9. #19
    Jan 2009
    This is the new file I just downloaded, changed and put on the site:
     * @copyright Copyright 2003-2007 Zen Cart Development Team
     * @version $Id: additional_images.php 6132 2007-04-08 06:58:40Z drbyte $
      die(
    'Illegal Access');
    if (!
    if (
      if (
      } else {
      if (
        while (
          if (!
            if (
    if(preg_match("/" $products_image_base "/i"$file) == 1) {
                if (
                  if (
                  } else {
        if (
    $dir->close();
    $title '';
    if (
    $num_images) {
    $row 0;
    $col 0;
      if (
      } else {
      for (
    // bof Zen Lightbox 2008-12-11 aclarke
    if (function_exists('handle_image')) {
        } else {
    // eof Zen Lightbox 2008-12-11 aclarke
    $flag_has_large file_exists($products_image_large);
    if (ZEN_LIGHTBOX_STATUS == 'true') {
          if (
    ZEN_LIGHTBOX_GALLERY_MODE == 'true') {
    $rel 'lightbox-g';
          } else {
    $rel 'lightbox';
    $script_link '<script language="javascript" type="text/javascript"><!--' "\n" 'document.write(\'' . ($flag_display_large '<a href="' zen_lightbox($products_image_largeaddslashes($products_name), LARGE_IMAGE_WIDTHLARGE_IMAGE_HEIGHT) . '" rel="' $rel '" title="' addslashes($products_name) . '">' $thumb_slashes '<br />' TEXT_CLICK_TO_ENLARGE '</a>' $thumb_slashes) . '\');' "\n" '//--></script>';
        } else {
    $list_box_contents[$row][$col] = array('params' => 'class="additionalImages centeredContent back"' ' ' 'style="width:130px;" ',
    $col ++;
        if (
    $col 0;
    $row ++;
    // end for loop
    // endif
  10. #20
    Aug 2006
    UK
    OK! now that is the same file that I am looking at.... and I do not see any reason why the change of code for the in line style is breaking this...
    ~Steve~
  1. Problem with additional images layout
    By webmiss in forum Templates, Stylesheets, Page Layout
    Last Post: 13 Nov 2011, 11:00 PM
  2. Problem with additional images
    By Craftystash in forum Customization from the Admin
    Last Post: 14 Jul 2009, 10:51 AM
  3. problem with additional images box in IE
    By koenvandamme in forum Templates, Stylesheets, Page Layout
    Last Post: 23 Mar 2009, 10:31 AM
  4. Bug Opera with categories image display
    By cshart in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Dec 2007, 06:33 AM
