Hello great wizards of Zen!
I'm having some major problems with ordering any quantity of products more then 1. Noone can order more then 1 item at a time. At first I didn't have the quantity box showing at all. Now its there but its always at 1 when added to cart.
NOTE: The quantity DOES WORK THROUGH Category listings - that is when you go to a category such as: Components and then click on any of the categories, for example - Keyboards.
AFTER - DO NOT ADD THE ITEMS HERE and DO NOT CLICK ON ADD SELECTED TO CART - GO INSIDE ANY OF THE PRODUCTs. Lets say - pick the first product - Saitek PZ30AU Black USB Keyboard - click on the picture or its title - which will take you inside the product and you will see a COMPLETE description of the item there. On the bottom - you see an "ADD TO CART" button - so FROM HERE - if you try changing the quantity - it will always be 1!
I have tried everything. I've a fellow Zenner already try helping me and he had no luck eitherI'm really hoping somebody could guide me in the right direction on what I need to change.
