Results 1 to 8 of 8
    Apr 2009
    Default help with strange popup window appear
    refer to http://www.ecomputer.com.au/index.ph...roducts_id=500
    at bottom a lot of strange image appear.
    Apr 2006
    Texas
    Default Re: help with strange popup window appear
    Lo,
    Looks like Template Monster is using a banner for X'mas
    Check your banners: admin panel/ tools/ banner manager
    Apr 2009
    haredo,seem nothing to do with xmax banner,yesterday i added product description then these stuff suddenly appear. are they virus?they appear in several product only but not all product.
    Apr 2006
    Texas
    Lo, Are you talking about the larger images below the desccription.. Need more detail please...
    Apr 2009
    Apr 2006
    Texas
    Lo,
    Drats this is the old Template Monster.. A Meanie...
    Try this first,
    admin panel/ catalog/ product types/ product - general, click on right hand side edit layout
    1. Show Product Additional Images
    2. Set to 0
    If this does not work we will control her from the
    includes/templates/theme171/css/stylesheet_tm.css
    Apr 2009
    haredo you are the best,problem solved thanks a lot.
    Apr 2006
    Texas
    Lo,
    Your Welcome,
    An apple a day keeps Louis Away :)
  1. Help larger image popup wrong window
    By freedude in forum Customization from the Admin
    Last Post: 23 Mar 2011, 09:29 PM
  2. Problem with position of image in popup window
    By SandraJ in forum Templates, Stylesheets, Page Layout
    Last Post: 21 May 2010, 03:21 AM
  3. Please help!! Description in popup window
    By piccolapixie in forum Templates, Stylesheets, Page Layout
    Last Post: 26 Jun 2009, 03:30 PM
  4. Help with Popup Window Size
    By malhyp in forum Templates, Stylesheets, Page Layout
    Last Post: 5 Feb 2009, 05:33 AM
  5. Make Help link lightbox instead of popup window
    By dreamz in forum Templates, Stylesheets, Page Layout
    Last Post: 8 Feb 2008, 04:31 AM
