    May 2009
    Default Help - Additional Images Not Appearing, Did everything
    Just setting up ZenCart and followed the tutorial on Additional Images. Put them in the LARGE folder with proper _LRG extension, etc. They are not showing up. Using BareBones template - thought it was that, switched to Apple template - still no images. Looked through all the admin parameters and everything seemed set right. Am I missing something simple??
    Website with sample product: http://bowlinsun.com/zencart/index.p...&products_id=3
    T.I.A.
    Aug 2004
    New York City
    Default Re: Help - Additional Images Not Appearing, Did everything
    Can you post the name of the main image for the item and the additional images you expected to be shown?
    May 2009
    Quote Originally Posted by afo View Post
    Yes- Main Image: Bow_LRG.jpg
    I also had the main image as Bow_01_LRG.jpg but that didn't seem to work either.
    Here's the complete file path: http://www.bowlinsun.com/zencart/ima...ge/Bow_LRG.jpg
    Feb 2007
    Burleson. Texas
    Quote Originally Posted by RumHead View Post
    Have you tried Bow.jpg as the main image?
    Dennis
    www.stampdays.com
    Over 80,000 stamps and still growing!
    May 2009
    Quote Originally Posted by awhfy99 View Post
    Thanks! Just did and it worked. Much appreciated.
    1.5 miles from Home
    T.I.A.
    This tutorial?
    https://www.zen-cart.com/tutorials/index.php?article=58
    You have your additional images in the "large" folder.
    Images in the "large" folder display via the pop-up window.
    (it's in the tutorial)
    Your using Zen Cart default image handling.
    So you should have your main image here:
    http://www.bowlinsun.com/zencart/images/Bow.jpg
    Additional images:
    http://www.bowlinsun.com/zencart/images/Bow_01.jpg
    http://www.bowlinsun.com/zencart/images/Bow_02.jpg
    http://www.bowlinsun.com/zencart/images/Bow_03.jpg
    hth
  1. Need some help with additional images not showing correctly.
    By annav in forum Setting Up Categories, Products, Attributes
    Last Post: 15 May 2013, 10:26 AM
  2. v139h Additional Images not appearing
    By lemonygem in forum Templates, Stylesheets, Page Layout
    Last Post: 8 Aug 2012, 02:15 PM
  3. Did I just lose EVERYTHING?????
    By spleify in forum Installing on a Linux/Unix Server
    Last Post: 20 Oct 2010, 03:42 PM
  4. New Images not appearing.
    By Bigrhino in forum Setting Up Categories, Products, Attributes
    Last Post: 8 Aug 2008, 06:49 PM
