Results 1 to 10 of 19
    May 2009
    Default order id problem
    hi, hope someone can help me out, after i have changed the order id from 1 to 24468 using tools > store manager then i test my creditcard with a sample item that price 0.01, i tested 2 times, it works well, first time 24468 order id, then second time 24469 order id, i both got all the mail from my site and these order do write into my database, so i though i'm done in this part however
    the problem happens , one buyer purchase my item through my site today, then my paypal got the payment, i see his address well in the paypal, but then i cannot see any order history in my site, so then i'm going to test payment again then i find out everytime after i check out i go to the paypal page and enter my creditcard number and then it prompt up the credit card number cannot be use (only the first time checkout it happens), but if i click back to merchant and check out again, the credit card number can use in paypal and make the payment, and why is it happen?
    after make the payment, in the order confirmation page it shows to me that the order id is always 24469, that means it never increase by 1 anymore the order id, and of course there is no buy history now in my zencart~~
    May 2009
    Default Re: order id problem
    ok here is my orders table only 3 rows so far and i 've seen the orders_id here, the orders_id is set to be auto increment
    orders_id customer_id .. .. ..
    1 1
    24468 1
    24469 1
    and order_products id
    table
    order_prodcuts_id orders_id
    1 1
    2 24468
    3 24469
    why the orders_id lost its increment value? is it a key that because it lost its increment value so it cannot log the history into my cart anymore? thx
    May 2009
    and ok if i just do not care the order id and the previous test order history , how could i reset all of these back to normal ?? i do not want to import back my database again since i did add a lot of items previosuly, is that i can truncate the table orders and orders_products? it seems will have a problem if i manually truncate the database
    May 2009
    and further more i'm now trying to use the reset order id to higher number from 24469 to something 32570, and i test with the payment again, i can pay with the creditcard, and the order no at the confirmation check out page is 32570, but then when i try another purchase again the problem still exist, the reset id yes can reset one time , but if i make 2 purchase later on the id number frozen and cannot increment , and i found out that the order id just overwrite the last row's order's id ! (previously i have 3 order that is order 1, order 2 and order 24469, and now become order 1, order 2 , and order 32570)
    how to reset all these problem in fact? thank you it takes me so long time now
    May 2009
    ok now i keep searching post and trying to recover the system, i just wanna reset all and delete all the orders history etc, i do search and i truncate all the table related to orders, and suppose that will work and then test to purchase through my store again, yes again i can pay with the paypal with my creditcard , but once i click back to merchant page, the success check out page show
    your order number is :
    you've got a blank order number after i truncate all the data in orders related table
    and again no history in my zencart after payment, the payment is success, and it never write any data into the order related tables, any idea ? thx
    ALL of your "problems" with order_id apparently not incrementing are related to a problem your server has with PayPal. It has *nothing* to do with your orders tables or auto_increment at all.
    When you use the PayPal IPN / Website Payments Standard module to make payments, your server must wait for PayPal's server to contact your server to notify it of the payment. If *anything* goes wrong in that communication, you'll never see the order in your store.
    See this article for troubleshooting steps to try to resolve the problems between your server and PayPal's server: http://www.zen-cart.com/wiki/index.php/PayPal
    Also, switching to Express Checkout instead of Website Payments Standard/IPN will avoid the problems you mention.
    May 2009
    hi dr. i did read all these carefully and i've been trying on this whole day, i'm using a godaddy host, i've turned the crul setting off, or even follow to add the false && for an alternative fix, it still cannot solve the problem
    i don't have a business paypal a/c right now so is that godaddy cannot work with standard ipn?
    What's showing in the PayPal log files since you enabled debugging?
    May 2009
    i did use your suggest method to check my ipn , i downloaded the ipncheck 139 and upload to my site
    here is the result
    IPNCHECK.PHP - Version 1.3.9
    IPN TESTING - Response Received via CURL -- COMMUNICATIONS OKAY
    IPN TESTING - Confirmation/Validation response with fsockopen(): FSOCKOPEN() RESPONSE RECEIVED - Communications OKAY
    Default method likely to be used for communications is: CURL, with the fallback method being FSOCKOPEN if possible.Script finished.
    where to see my paypal log? i can see the ipn history log and all the ipn status is retrying that means nothing can pass back to my site
    May 2009
    okay i searched your post again and in zencart payment turn debug mode to log file and i'm going to make a few try again to post back what i can see in my log file thx
  1. Order Problem
    By DonM in forum General Questions
    Last Post: 6 Jun 2008, 09:52 PM
  2. Order Problem
    By wmowat in forum Managing Customers and Orders
    Last Post: 18 Nov 2007, 06:50 AM
  3. Order Confirmation problem
    By Autobilstereo in forum General Questions
    Last Post: 17 Sep 2007, 10:29 AM
  4. Order problem
    By davek7 in forum Built-in Shipping and Payment Modules
    Last Post: 12 Aug 2006, 03:06 AM
