    Mar 2007
    Default Help - where has my sitemap gone?
    I am setting up a site and was linking to the sitemap using EZ pages in the header
    http://91.198.165.221/~cylinder/inde..._page=site_map
    This was working with links to all the pages appearing on the sitemap but seems to have disappeared overnight. Obviously I know this can't be the case but it has been a while since I worked on the site and so can't remember the last thing I was doing which might have caused a change.
    Does anyone have any ideas why the sitemap is not displaying? Which file builds the sitemap? What can I do to re instigate the site map.
    Thanks in advance for your help
    May 2008
    Default Re: Help - where has my sitemap gone?
    There are some coding errors at your site map page, as you can see the footer is also not displaying. This means there are some php errors within and the server can't process it and stop there.
    You can try the debug tools in here http://www.zen-cart.com/forum/announ...php?f=136&a=12 to find out where you problems are.
    Have Fun. Keep it Zennish!
    Mar 2007
    Thanks for the link. This has helped! I downloaded the debug tool and was able to trace the problem back to poor syntax in tpl_site_map_default.php. This was due to me trying to comment out something a while ago that I did not want to appear in the site map
    Mar 2007
    Thanks for the link - I have used the debug tool to track down the problem
  1. v154 Where has basket data gone?
    By JohnH in forum General Questions
    Last Post: 15 Feb 2016, 04:47 PM
  2. Where o Where has my EZ Pages Header Gone?
    By wudchuk in forum Templates, Stylesheets, Page Layout
    Last Post: 18 Oct 2009, 06:00 AM
  3. Where has the categories header gone?!?
    By 1kell in forum Templates, Stylesheets, Page Layout
    Last Post: 19 Feb 2009, 12:48 AM
  4. what has gone wrong? HELP!
    By Soul39 in forum Installing on a Linux/Unix Server
    Last Post: 7 Jan 2009, 01:46 PM
  5. My zencart has no sitemap Help
    By touchclothing in forum General Questions
    Last Post: 17 Oct 2008, 10:37 PM
