I was hoping to have Fast and Easy Checkout installed on my Zen Cart this morning by Numinix.
Since it will be 48 hours, I guess I need to do this myself.
fec: 1.4.2
ZenCart: 1.3.8
My understanding of the installation is
1. Place all files in the "required_files" folder to the same location on my site (ignor "previous_sql_updates" since I have the latest versions)
2. Copy and paste the "install.sql" text into ADMIN > TOOLS > INSTALL SQL PATCHES
3. Make the change to application_top.php if I am using Magic SEO URLs[/list]
Is this right?
What about these files
* license.txt
* order_total_class_edit.txt
* update_1_4_3.sql
* uninstall.sql
Someone else set up this Zen Cart so I am not sure what MODs have been added. How do I check for Magic SEO URLs?
Are there any other issues that I need to look out for?
Is there anything that I missed here?
I have tried the steps listed above on a dummy Zen Cart and I am having an issue with entered fields not being recognized when checking out without an account.
This is pretty critical as I need to add this MOD to a Zen Cart that, by default, you checkout without an Account.
Dummy Site:
http://timothynpayne.com/shop/
