Im using 1.3.8 zencart and i installed it in two domains with diferent Databases that are hosted in the same server.
I just installed the security updates in one of the instalations.
I only chaged graphics and some text in one of the stores, i havent finished tweekin the stores.
the stores dont give errors but they are displaing boith the same products dunno why.
i installed 1.3.7 in other webs and worked fine
Thank you all for your atention i would apreciate your help guys.
Best regards;
Antonio
thank you very much iŽll try it now iŽll post here if it worked out.
