Results 1 to 9 of 9
    Jul 2009
    Default Problem with Column Layout Grid for Product Listing
    Hi there,
    I am trying to install Column Layout Grid for Product Listing from the free add ons - but its not working when I set it up. Is it something incorrect with the PHP/set up or is it missing some css?
    Should be in a 3 column grid:
    http://www.skincarepichost.com/index...index&cPath=65
    Thank you in advance! Liz
    Jul 2009
    Default Re: Problem with Column Layout Grid for Product Listing
    I am able to get the add on to work in other templates, just not this one. What should I check for? The files are identical, so I am not sure whats going on.
    Jul 2009
    Nevermind, newbie mistake - misnamed the folder :-)
    Apr 2008
    i think i am having similar issue with this site (testing installation):
    http://www.metalmultimedia.com/whole.../wholesomcart/
    i have installed the column layout grid, run the sql query, set the product listing settings to columns and 3 columns, etc. i have scoured this site for similar issues AND this was the only post i could find with the closest issue to my own.
    just like your original issue, my mod works with classic template but not my customized template. i have checked and rechecked everything and it seems like my columns should be working and aren't. i am hoping that i misnamed the same folder maybe? which folder was it that you misnamed? i am hoping against all hope that it is the same one for me. LOL.
    additionally someone suggested that it might be single columns hard coded into my template ??? HOWEVER i didn't actually do anything of the sort that i remember, BUT who knows ?? but in that listing, no mention of how i might fix this was included, so… does anyone know where i would check for this? if i can find it, i might actually be able to stumble onto a fix.
    any help is appreciated. thanks.
    Feb 2005
    Lansing, Michigan USA
    When you renamed the YOUR_TEMPLATE folders in the mod files, did you name them 'wholesomecart"?
    It would be almost impossible to hard-code a single column by accident.
    You might try re-uploading the mod folders and files.
    Apr 2008
    OK yes i've tried deleting and reuploading the mods again without luck
    as far as names i followed the instructions as closely as possible. the folder in the includes/modules folder is named "wholesomtemplate," the same as my template folder name AND the folder inside of the includes/templates/wholesomtemplate folder (which is my template folder) was named "templates" just as it appears in the instructions and the directory structure of the mod files themselves. AND as i said before it works if i use a different template, like the classic template, just not my customized template.
    thanks for any help you can provide i really appreciate this, because i am stumped. seems like it should work ???
    Apr 2008
    something just occured to me.
    i notice that the column setting show up in the product listing settings, which i assume apply to the product listings within each category. could this be the problem? i want to use this mod for the main categories i have set to show up on the main page not just the product listings within each category. am i using this mod wrong? if so, would it be possible to use with the categories at all? again thanks for any help.
    Feb 2005
    I believe that mod only affects the product listing.
    Apr 2008
    that's what i was afraid of LOL. thanks again for trying to help i feel a little silly for not paying closer attention to the readme
    do you know of anything that will provide a grid for the main page categories? thanks.
  1. Problem with column layout grid for product listing 1.3.8
    By ivanc in forum Templates, Stylesheets, Page Layout
    Last Post: 22 Jul 2010, 11:00 AM
  2. Replies: 5
    Last Post: 17 Feb 2010, 05:13 PM
  3. Column Layout Grid for Product Listing doesn't work with Firefox?
    By pamcake in forum All Other Contributions/Addons
    Last Post: 23 Oct 2008, 07:00 PM
  4. Column/Grid Layout for Product Listing Problem
    By Garenthino in forum Templates, Stylesheets, Page Layout
    Last Post: 23 Aug 2007, 06:44 PM
  5. Problem with Column Layout Grid for Product Listing 1.3.0.2
    By mmmfruit in forum Templates, Stylesheets, Page Layout
    Last Post: 12 Aug 2006, 04:15 PM
