Results 1 to 8 of 8
    Mar 2009
    Trowbridge, Wiltshire
    Default Display Problems in IE7 and Firefox
    Hi I have just moved my store to an online ISP and have been using IE6. Everything seemed to be great (on my system) until a few users using Firefox and IE7 have complained that the store doesn't display properly. I am using Zen Cart 1.3.8a.
    Has anyone come across any problems like this, and if so is there a fix or some additional css code for these browsers?
    Many thanks
    Scott
    Feb 2005
    Lansing, Michigan USA
    Default Re: Display Problems in IE7 and Firefox
    Everybody has come across problems like this. We'll need a link to your site.
    Mar 2009
    Thanks stevesh,
    the site is: http://www.cmsspares.eu
    Many thanks
    Scott
    Nov 2005
    Colorado Springs, CO USA
    You are using two stylesheets
    stylesheet.css and stylesheetnew.css
    both of these stylesheets appear to contain the same information You don't need both of them
    I'd compare the two and combine them into just one stylesheet.css and then delete stylesheetnew.css
    Feb 2005
    First thing: Zencart loads all stylesheets with the .css extension that are in the current template's css folder, so you have two fighting each other. Rename the one to stylesheet.old.
    Then, adding the part in red should fix the only problems I see:
    #navBreadCrumb {
    padding: 0.5em 0.5em;
    background-color: #FFFFFF;
    font-size: 0.95em;
    font-weight: bold;
    margin-top: 2em;
    Mar 2009
    Awesome - thanks guys much appreciated.
    the css change has made a big difference!
    The only other problem is that for some reason the 100% height setting I had in doesnt seem to work any more - it was perfect in IE6!
    Thanks again
    Scott
    Nov 2005
    Try removing the height definition
    #mainWrapper {
    background-color: #ffffff;
    height: 100%;
    text-align: left;
    width: 900px;
    vertical-align: top;
    border: 1px solid #9a9a9a;
    Mar 2009
    Thanks clydejones - that has done the trick. It looks great now!
    Thank you very much - I really appreciate the help.
    Regards
    Scott
  1. ie7 and chrome different than ie8 and firefox
    By Congerman in forum Templates, Stylesheets, Page Layout
    Last Post: 14 Aug 2010, 04:48 PM
  2. Display anomolies between IE7 and Firefox 2
    By ajhb in forum Addon Sideboxes
    Last Post: 3 Nov 2008, 04:05 PM
  3. IE7 and Firefox problem
    By livingstons in forum Templates, Stylesheets, Page Layout
    Last Post: 27 Oct 2008, 04:23 PM
  4. Two problems with IE7 vs Firefox
    By digger149 in forum Templates, Stylesheets, Page Layout
    Last Post: 28 Jul 2007, 01:56 AM
  5. IE7 & Firefox layout problems
    By AngelusUK in forum Templates, Stylesheets, Page Layout
    Last Post: 19 Sep 2006, 04:46 PM
