I've spent a lot of time researching what should be a simple problem, but it's causing me headaches.I've installed multiple Zen Carts so this is something I should be used to, but every install is new.
The site isn't loading properly after a site move from a test folder to the new site. I double checked all the config variables and they are correct.
I moved all files via Filezilla, and I know all the files moved properly.
I've tried the debugging tool and it didn't throw up anything in the log.
Here is the URL:
https://waterfowljunkie.com/
Any ideas?
