Results 1 to 10 of 25
    Dec 2006
    Default SSL Problem (Base href???)
    Hi there,
    Could someone please look at http://www.hairrigs.com ?
    I've just installed SSL but I'm getting errors saying that some items are not secure. It appears that (for starters) all the CSS is not secure because just prior to the stylesheet lines in the code there is...
    <base href="http://www.hairrigs.com/" />
    configure.php looks like this...
    define('HTTP_SERVER', 'http://www.hairrigs.com');
    define('HTTPS_SERVER', 'https://www.hairrigs.com');
    define('ENABLE_SSL', 'true');
    Certificate is issued to http://www.hairrigs.com
    Any ideas anyone??
    Dave
    Jun 2005
    Cumbria, UK
    Default Re: SSL Problem (Base href???)
    Zencart will only invoke SSL when there is a need for it... Such as when people send personal or payment data over the internet. SSL slows a site down, so you don't want SSL all the time.
    If you are getting "This page contains insecure elements" warnings, it means that when it is in https mode, the page has links in it that are not https.
    Generally, these occur when you hard-code hyperlinks, or call a url into a page which is absolute and http.
    When the warning appears, it will ask you "Do you want to display these elements?"
    Choose "NO"... and you can then inspect the page for the problem URL's and decide on your course of action with these links.
    20 years a Zencart User
    Dec 2006
    Hi there,
    Thanks for your reply. I understand the bits you mention and I don't have SSL on the whole site, just the checkout pages etc.
    I've already determined that it's the CSS that is not secure as it's being called as http:// rather than https:// due to the base href command before the stylesheet lines.
    Any ideas?
    Cheers,
    Dave
    N of San Antonio TX
    Your stylesheet is probably the ONLY correct link on the login page.
    Most all the others are hard-coded. No matter what you do to those, the Google link will continue to bomb the ssl.
    I see we have a new contender in the messed up template category. TM meet Acadame
    A little help with colors.
    Dec 2006
    Uh-oh, that doesn't sound good. What's TM?
    Could you suggest which files I need to start editing to put things right? Is it just a case of changing the links from absolute to relative?
    Dec 2006
    Looked at the files and I see it's not as simple as I thought....
    Ditch Acadame or learn php?
    N of San Antonio TX
    There are so many things
    TM is template monster and it appears your template is trying to join them in manipulating code that looks great till you need to make the slightest adjustment. In TM's defens, I've never seen the absolute links in their log in pages.
    First clue of problems (to me), is the Log Off and My Account links which (in real Zen Cart) wouldn't show up till I was logged in to the site.
    Try backing out of this template to the classic template and see what happens with the ssl. My guess is you won't see any absolutes in the page source (with the possible exception of the Google link mentioned before)
  1. v138a ssl issue with base href and load balancer
    By peeceelee in forum Basic Configuration
    Last Post: 17 Nov 2012, 05:16 PM
  2. v139h SSL Nonsecure Items Problems w/ Base href
    By coledorsey in forum Basic Configuration
    Last Post: 27 Feb 2012, 02:45 AM
  3. base href problem
    By cricles in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 20 Jul 2010, 06:34 AM
  4. https error relating to base href SSL
    By little dog in forum Basic Configuration
    Last Post: 18 Dec 2007, 08:12 AM
