Results 11 to 20 of 25
    N of San Antonio TX
    Default Re: SSL Problem (Base href???)
    there should not be any cart links that start with http://. That would automatically take it out of ssl.
    Hard to tell without looking at your site. do you have any mods installed?
    A little help with colors.
    Dec 2006
    Yeah, a few mods. Simple SEO Urls, fast and easy checkout, google base feeder, google checkout, google analytics.
    I backed up after each modification (but didn't have my SSL installed until the end) so I'm going to restore each backup to another domain starting with the first and try to work out where it all went wrong.....
    Dec 2006
    Totally confused now....
    Just done a fresh install (to http://www.hairrigs.com again)
    still getting the SSL problems and still seeing
    <base href="http://www.hairrigs.com/" />
    in the source.
    Why doesn't my fresh install put
    <base href="https://www.hairrigs.com/" />
    instead?
    Apr 2006
    West Salem, IL
    What do you have in your .htaccess file?
    Mike
    AEIIA - Zen Cart Certified & PCI Compliant Hosting
    Dec 2006
    Totally fresh install, so no .htaccess file in web root.
    Dec 2006
    Just been in touch with my webhost who say it's the way their SSL is set up. PHP isn't detecting the fact that the pages are SSL.
    They have given me a couple of options and are going to make some changes at their end I think.
    Will post again if there are any other problems related to this.
  7. #17
    Oct 2006
    Quote Originally Posted by DaveS View Post
    It's probably the way how their SSL is set up, and as I vaguely remember DrByte also posted a temporarily fix somewhere, but it's the best if your host can fix it on their end.
    I no longer provide installation support on forum for all my modules. However, if there are real bugs with the modules please feel free to contact me
  8. #18
    Dec 2006
    They have suggested just removing the base href command initially and if that doesn't work they have a more complex fix.
    Will have a look for DrByte's solution too.
  9. #19
    Oct 2006
    If you remove it, you wont be able to use any module that modify your urls, also, you may have other problems down the road. It's their problem, make them fix it. They have to fix it.
  10. #20
    Dec 2006
    OK, thanks for that info - that will save me more headaches when I try to put all my modules back on.
    Will contact them and see what they say.
    Cheers,
    Dave
  1. v138a ssl issue with base href and load balancer
    By peeceelee in forum Basic Configuration
    Last Post: 17 Nov 2012, 05:16 PM
  2. v139h SSL Nonsecure Items Problems w/ Base href
    By coledorsey in forum Basic Configuration
    Last Post: 27 Feb 2012, 02:45 AM
  3. base href problem
    By cricles in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 20 Jul 2010, 06:34 AM
  4. https error relating to base href SSL
    By little dog in forum Basic Configuration
    Last Post: 18 Dec 2007, 08:12 AM
