Results 1 to 10 of 12
    Feb 2004
    Default Problem with Top Navigation
    My Top bar on
    www.NothingButCostumes.com
    has some colorful tabs at the top.
    To the Far Right there are some Trailing :: :: :: ::
    How can I get rid of them?
    N of San Antonio TX
    Default Re: Problem with Top Navigation
    Template Monster, right?
    Try turning off the Bread Crumbs Navigation Separator in the Layout Settings menu under Configuration in the Admin.
    A little help with colors.
    Feb 2004
    Yes... Its a Template monster template....
    I first tried setting the breadcrumb status to 0
    then took it out completely.
    Yet its still there...
    If it were the ez-pages menu, I would say to look at the admin > Configuration > EZ-Pages > EZ-Pages separator definition. As it appears to be a custom menu, you will probably have to look at the PHP file for it, whatever that may be. Maybe it is just renamed for the sake of "originality"...
    Feb 2004
    It is an EZ Pages Menu
    So an EZ-Pages separator definition sounds like the problem.
    I dont have a Configuration > EZ-Pages
    in that menu....
    Is there supposed to be one in 1.3.7?
    N of San Antonio TX
    Ready to receive?
    This is why they have the posting tips. After looking and trying to figure out where this will be in TM code versus REAL code, you drop the 1.3.7 bomb?
    Sorry, I don't think I'll be loading 1.3.7 to check out the diffs. If I were you, I be taking my database to 1.3.8a with a new design that is NOT TM. Just my 2.875 cents worth.
    Configuration > (bottom of the list) EZ-Pages Settings >
    EZ-Pages Header Link Separator  ::
    Feb 2004
    If I Upgrade the DB without the files
    would that get me the menu? My site is heavley modded
    so I would have to be careful overwriting the files.
    The EZ-Pages Settings menu has been in admin for a long time, and your template would not have removed it.
    I wouldn't try to upgrade just the db, as that might cause problems with some 1.3.7 files.
    Feb 2004
    I rolled it back.
    Took out the template...
    Put an ad on craiglist for someone to help me
    upgrade. Its not the Upgrade that scares me.
    Its the whole run against Win Merge and try to hack through all
    the mods I installed.
    Never did that before? For a Novice is it painful?
  1. Increasing with of just the top navigation bar
    By ozjewels in forum Templates, Stylesheets, Page Layout
    Last Post: 14 Jun 2012, 09:50 PM
  2. defect with my top navigation
    By kylepoyser in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Sep 2010, 01:05 AM
  3. Newbie -- Looking for templates with top Navigation bar, no columns
    By stevewag in forum Templates, Stylesheets, Page Layout
    Last Post: 17 Apr 2009, 07:44 PM
  4. Problem top navigation
    By nikita in forum Templates, Stylesheets, Page Layout
    Last Post: 9 Mar 2008, 07:26 PM
  5. Top navigation Problem
    By ellis200200 in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Jul 2006, 09:00 AM
