I've turned on two boxes in right column, specials and best sellers. I don't know why they are not appearing on the product info (product details) page?
Is there any setting in the admin configuration to turn it off or on?
Regards
Regards
Specials says ...
Best Sellers says ...Code:if (isset($_GET['products_id'])) { $show_specials= false; } else { $show_specials= true; }
So Specials are, by design, not showing on the product _info ...Code:// test if box should display $show_best_sellers= false; if (isset($_GET['products_id'])) { if (isset($_SESSION['customer_id'])) { $check_query = "select count(*) as count from " . TABLE_CUSTOMERS_INFO . " where customers_info_id = '" . (int)$_SESSION['customer_id'] . "' and global_product_notifications = '1'"; $check = $db->Execute($check_query); if ($check->fields['count'] > 0) { $show_best_sellers= true; } } } else { $show_best_sellers= true; }
Best Sellers are, by design, showing based on is customer logged in and has global notifications turned on ... if not logged in, then it does not show ...
You could customize these further with your templates and overrides to always show ...
Thanks Ajeh,
I'll override the template then.
Thanks and Regards
