Results 1 to 10 of 17
    Jun 2008
    Default Preview button doesn't work - can't add products
    I moved a site to a PCI compliant hosting company. Customers can buy from the front end, and I log into to the admin, however the following buttons don't work:
    • Save button, when creating a new category
    • Preview button, when creating a new product
    • Preview button, when amending a product
    • Update button, when changing status of an order
    Looking around the forum, over aggressive mod_security rules were mentioned, however the host tells me "[FONT=Times New Roman][FONT=Verdana]We do not use mod_security, but we do use Suhosin[/FONT][/FONT]"
    Any idea what it could be? Thanks in advance!
    John Crumpton, Technical Director of Double Sided
    Zen cart shop: Buy happie loves it
    Feb 2005
    Lansing, Michigan USA
    Default Re: Preview button doesn't work - can't add products
    Jul 2009
    I have something similar. I just added the security patch. I since tried to add a new category to my site, but the "save" button doesn't seem to effect the change. Not sure where to start to find the problem here.
    Feb 2005
    Karen - that's one possible symptom of installing the security patch incorrectly. It's possible you installed the files to the cart directories rather than admin.
    Jul 2009
    I wish that were true, I could easily fix it. But I did put the patch files and the one modified file back in the newly renamed admin area. Any other directions you could point me in?
    It also may have been nothing to do with the patch. It's just that is the most significant change I have made to the store files other than regular item updates etc. in quite some time.
    I can add new products just fine. Only seems to be affecting the new category section. I can do a workaround for now. But there will come a time...
    Thank you for responding!
    Jun 2008
    Stevesh - thanks for responding - I've asked the host where php.ini is for me to add
    suhosin.session.encrypt = off
    Otherwise I checked if I had incorrectly installed the security patch and I had uploaded all files to my admin folder.
    Jun 2008
    The hosting company now says:
    [FONT=Times New Roman][FONT=Verdana]"It should not be causing problems. There may be something else that is causing your problem. Have you tried to contact ZenCart to see if they have any solutions or ideas?"
    Should I look for another host? Anything else you suggest I try?
    [/FONT]
    [/FONT]
    Feb 2005
    Quote Originally Posted by dsided View Post
    [/FONT]
    [/FONT]
    I'm not sure you have a choice. DrByte says Zencart won't work with
    suhosin, and he'd know, so ...
    I guess I don't understand why they won't let you turn it off, though.
    You might look at the Certified Hosts.
    Jun 2008
    Thanks for the tip. I did a blank install of v1.3.8a/v1.3.8 to a test directory and the buttons work fine(!)
    I'm going to try patching to the latest release and see if that still works.
    Jun 2008
    I've now patched to security_patch_v138_20090619 and the buttons DON'T WORK!
    I'm going to remove the patch until this is resolved. DrByte what info about my server configuration do you need?
  1. template preview doesn't work
    By ebaobao in forum Bug Reports
    Last Post: 3 Oct 2011, 08:45 PM
  2. details button in ie doesn`t work
    By aszu in forum General Questions
    Last Post: 26 Oct 2010, 01:21 AM
  3. Replies: 3
    Last Post: 25 Oct 2010, 04:39 PM
  4. Add to cart button sometimes doesn't work
    By eastwood in forum Bug Reports
    Last Post: 3 Nov 2009, 03:51 PM
  5. My form submit button doesn't work
    By timjbart in forum Templates, Stylesheets, Page Layout
    Last Post: 21 Aug 2008, 11:25 PM
