Results 1 to 10 of 20
    Aug 2009
    Bedford, England
    Default Desperatley Need Help with PHP / MYSQL code
    Hi everyone.
    Please Please Please can someone help me?
    I am trying to set up a php page that updates product qty's in the database. I almost have it working, however seem to have hit a brick wall.
    The php simply reads an XML file which contains Product Codes & Qtys, and then $variable echo's are used in the mysql queery to UPDATE the database.
    All works perfectly apart from when I have a product code that is alpha numeric.
    For Example, My php file reads the XML and will find product codes as they are in the XML: i.e $productcode will echo 28923 or 28374S.
    Now, the mysql syntax im using that works fine with numbers is:
    UPDATE products_with_attributes_stock SET quantity = 100 WHERE product_code = 28923
    This updates the quatity as it should as does the PHP file for any $productcode that echo's as just a number with:
    mysql_query("UPDATE products_with_attributes_stock SET quantity = $stock WHERE product_code = $productcode");
    What doesnt work is:
    UPDATE products_with_attributes_stock SET quantity = 100 WHERE product_code = 28374S
    this returns the error -
    Error
    SQL query:
    UPDATE products_with_attributes_stock SET quantity =100 WHERE product_code = 28374S
    MySQL said: Documentation
    #1054 - Unknown column 'product_code' in 'where clause'
    the value 28374S does exist! - I dont understand why mysql is returning this result..
    I have noted that if I repeat the syntax with double quotations i.e "28734S" it works! BUT this is no good as my $productcode is not echoing that!???
    In addition, I have managed to make my php echo the codes in double quotatons by doing $quote = '"'.$productcode.'"'; and using the following code for the syntax:
    mysql_query("UPDATE products_with_attributes_stock SET quantity = $stock WHERE product_code = $quote");
    BUT THIS ALSO DOESNT WORK!
    Please please please let there be someone out there that can tell me why this isn't working!???
    Is it my php code? is it the syntax? is it the way I have my table set up?? IM STUCK..
    Kind Regards
    Phil
    Default Re: Desperatley Need Help with PHP / MYSQL code
    Wrapping quote-marks around alphanumeric strings is absolutely important. A pair of single-quotes or a pair of double-quotes will suffice. Single is the usual approach when using strings.
    Also make sure your custom added "product_code" field exists in the table and that it's not a numeric/integer type. If it needs to handle strings it will need to be a varchar or char type (or text if it's huge data).
    Aug 2009
    Bedford, England
    OK - so I definatley need double quotes.
    Any ideas as to why when I use the $quote, which echos "24437S " it still doesnt work?
    is it my php code that is incorrect in the syntax string part ? How can I write it so it adds quotations to the queery?
    The custom field does exist and it is set to:
    product_code varchar(32) latin1_swedish_ci No
    I am desperate to get the php to run this queery and need a workaround.
    Thanks for you quick response, any further suggestions/advice would be greatly appreciated.
    Phil
    Quote Originally Posted by philip937 View Post
    1. I don't use "mysql_query()" when running inside Zen Cart, because the database abstraction layer inside ZC is smarter and safer because there are numerous data-typing (aka security) protection options available in it, etc.
    2. I *always* refrain from embedding variables inside double-quotes. While it's technically accepted, it can make for confusion when troubleshooting something that's going wrong. To keep it clear what's doing what, I always concatenate strings and vars separately instead. You'll see that pattern consistently throughout the Zen Cart code too.
    3. Since you want to use mysql_query() directly, this syntax should work just fine:
    mysql_query("UPDATE products_with_attributes_stock SET quantity = " . $stock . " WHERE product_code = '" . $productcode . "'");
    Aug 2009
    Bedford, England
    Thanks again for your quick response. That code didn't seem to work, this time it didnt even UPDATE to Number only codes? Any thing else I can try??
    You didn't mention any error message, so I can only assume it ran without one.
    If it's not working with that, then I'd be suspecting that the PHP logic you're using is faulty or your input data is bad ... or there are no relevant records to update.
    What if you replace the "mysql_query" call with just an "echo" call? ie: output the generated SQL to the screen, to see what it's really doing?
    Then what happens if you run that SQL in phpMyAdmin? What happens?
    Both of those steps can be very revealing of where you've got logic or syntax errors.
    Aug 2009
    Bedford, England
    the following is my php code, granted im a novice and its been peiced together form examples off the net. perhaps you could validate?
    $con
    mysql_connect('localhost''<username>''<password>);
    if (!$con) {
        die('
    Could not connect' . mysql_error());
    echo '
    Connected successfully';
    mysql_select_db('
    overplan_mirror');
    $rssFeeds = array ('
    supplier.xml');
    //Loop through the array, reading the feeds one by one
    foreach ($rssFeeds as $feed) {
      readFeeds($feed);
    function startElement($xp,$name,$attributes) {
    global $item,$currentElement;  $currentElement = $name;
    //the other functions will always know which element we'
    re parsing
    if ($currentElement == 'PRODUCT') {
    //by default PHP converts everything to uppercase
    $item true
    // We're only interested in the contents of the item element.
    ////This flag keeps track of where we are
    function
    endElement($xp,$name) {
    global
    $item,$currentElement,$productcode,$stock,$duedate;$conn;
    if (
    $name == 'PRODUCT') {
    // If we're at the end of the item element, display
    // the data, and reset the globals
    echo "<b>Product Code:</b> $productcode<br>";
    echo
    "<b>Stock:</b> $stock<br>";
    echo
    "<b>Due Date:</b> $duedate<br><br>";
    $ins_product addslashes($productcode);
    $ins_qty addslashes($stock);
    $ins_due addslashes($duedate);
    $productcode '';
    $stock '';
    $duedate '';
    $item false;  }}
    function
    characterDataHandler($xp,$data) {
    global
    if (
    $item) {
    //Only add to the globals if we're inside an item element.
    switch($currentElement) {
    case
    "PRODUCT_CODE":
    $productcode .= $data
    // We use .= because this function may be called multiple
    // times for one element.
    case
    "AVAILABLE_STOCK":
    $stock.=$data;
    case
    "DUE_DATE":
    $duedate.=$data;
    break;     }  }}
    function
    readFeeds($feed) {
    $fh fopen($feed,'r');
    // open file for reading
    $xp xml_parser_create();
    // Create an XML parser resource
    xml_set_element_handler($xp"startElement""endElement");
    // defines which functions to call when element started/ended
    xml_set_character_data_handler($xp"characterDataHandler");
      while (
    $data fread($fh4096)) {
        if (!
    xml_parse($xp,$data)) {
          return
    'Error in the feed';
    Also supplier.xml is in the following format:
    <StockValues>
    <Product>
    <Product_Code>00380 </Product_Code>
    <Available_Stock>3960</Available_Stock>
    <Due_Date>N/A</Due_Date>
    </Product>
    <Product>
    <Product_Code>00429 </Product_Code>
    <Available_Stock>4285</Available_Stock>
    </Product>
    <Product>
    <Product_Code>00495 </Product_Code>
    <Available_Stock>1035</Available_Stock>
    </Product>
    <Product>
    </StockValues>
    ********The Following is the php output echo from the code above as it is******
    mysql_query("UPDATE products_with_attributes_stock SET quantity = $stock WHERE smiffy_id = $productcode");
    Product Code: 00380
    Stock: 3960
    Due Date: N/A
    Product Code: 00429
    Stock: 4285
    Due Date: N/A
    Product Code: 00495
    Stock: 1035
    Due Date: N/A
    Product Code: 0122
    Stock: 2953
    Due Date: N/A
    Product Code: 0190
    Stock: 3434
    Due Date: N/A
    Product Code: 052A
    Stock: 550
    Due Date: N/A
    *********************When I echo the queery**************************:
    echo = ("UPDATE products_with_attributes_stock SET quantity = $stock WHERE smiffy_id = $productcode");
    UPDATE products_with_attributes_stock SET quantity = 789 WHERE product_code = 20320 Product Code: 20389L
    Stock: 11
    Due Date: N/A
    UPDATE products_with_attributes_stock SET quantity = 11 WHERE product_code = 20389L Product Code: 20389M
    Stock: 161
    Due Date: N/A
    UPDATE products_with_attributes_stock SET quantity = 161 WHERE product_code = 20389M Product Code: 20390M
    Stock: 87
    Due Date: N/A
    UPDATE products_with_attributes_stock SET quantity = 87 WHERE product_code = 20390M Product Code: 20390S
    Stock: 0
    Due Date: N/A
    UPDATE products_with_attributes_stock SET quantity = 0 WHERE product_code = 20390S Product Code: 20392L
    Stock: 160
    Due Date: N/A
    Im just about to echo the code you sent to see what that shows..
  1. v150 Need Help With MYSQL DB
    By gxjenkins in forum General Questions
    Last Post: 23 Dec 2012, 03:35 PM
  2. Need help with a mySQL Query
    By jeffmic in forum General Questions
    Last Post: 19 Dec 2010, 02:21 PM
  3. Basic mysql/php code with Zen help?
    By laurenjj in forum General Questions
    Last Post: 29 May 2009, 01:54 AM
  4. Need help with tpl_header.php code changes
    By BlessIsaacola in forum Templates, Stylesheets, Page Layout
    Last Post: 9 Mar 2008, 12:00 AM
