    Default Easy Populate problem
    i'm a newbie using easy populate and i was testing its functionality when i encountered an error.
    when i select the "Download Complete .csv file to edit (Attributes Not Included) " option i get this error.
    Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in /home/store.aumenta.com.mx/docs/aumenta/easypopulate.php on line 812
    I don't know if i installed easy poulate incorrectly or if there's another problem, i found some references to a similar problem but no answers to it.
    thanks!
    Jun 2005
    Cumbria, UK
    Default Re: Easy Populate problem
    What VERSION of Easy Populate?
    What VERSION of php is on your server?
    20 years a Zencart User
    Jul 2007
    United Kingdom
    Hi there,
    I am getting the same problem, I am running on Zencart 1.3.8 and the latest cvs version of easy populate.
    Should I go through the procedure of re-installing Easy Populate?
    ############################################################____
    [FONT=Arial]D Harper[/FONT] [FONT=Arial Black]www.dhdesigns4u.co.uk[/FONT]
    If at first you don't succeed, try, try, try again!!
    Jul 2007
    United Kingdom
    Hi There,
    Downloaded Easypopulate Again
    Uploaded New files
    Followed procedure to remove
    and re-installed
    et voila!
    All working well
    If at first you don't succeed try, try, try again!
    i'm using zen cart 1.3.8 and easy populate version 1.2.5.6.csv.2 and php 5.2.9.
    i'm going to uninstall easy populate and install it again
    thanks for the help!
    Apr 2004
    UK
    Try Version 1.2.5.4... works fine with zen 1.3.8a
  1. Easy Populate Problem
    By jax2 in forum All Other Contributions/Addons
    Last Post: 21 Jun 2014, 01:38 PM
  2. v150 Easy Populate 4 vs. Easy Populate CSV - What's going on with so many Easy Populates?
    By oleancomputers in forum All Other Contributions/Addons
    Last Post: 20 Jun 2013, 05:58 PM
  3. Easy Populate problem
    By scrapimages in forum All Other Contributions/Addons
    Last Post: 20 Oct 2011, 09:43 PM
  4. Easy Populate Problem
    By moejoe1976 in forum All Other Contributions/Addons
    Last Post: 29 Apr 2008, 11:03 PM
  5. easy populate problem
    By markantony80 in forum All Other Contributions/Addons
    Last Post: 26 Dec 2006, 09:11 PM
