Here are the two errors I get when you edit a product that has been imported using Easy Populate v 1.2.4.5:
Warning: reset() [function.reset]: Passed variable is not an array or object in D:\Inetpub\mywebsite.com\admin\includes\classes\object_info.php on line 29
Warning: Variable passed to each() is not an array or object in D:\Inetpub\mywebsite.com\admin\includes\classes\object_info.php on line 30
As you scroll down to look at the product all fields are blank.
However the image and product information is saved on the site if you view the site. everything looks ok.,
But if you want to edit the product from the admin side you get that banner error message at the top and blank fields from the product.
also I noticed that after importing a file you also get duplicate categories and the categories always get unsorted from the parent category.
How can i fix this problem...This site will have over 10,000 products and I don't have the time to edit each product without a database.
