Results 1 to 10 of 13
    Jan 2006
    Default curl_exec error 60 SSL certificate problem
    I have been using PayPal Direct Payments module for some time now and it just stopped working. We ahve had no orders since we updated our SSL Cert. I get this error in the logs:
    Dec 22 14:37:05 pgontang_api1.gmail.com [debug] Response XML:
    Dec 22 14:37:05 pgontang_api1.gmail.com [info] DoDirectPayment, Elapsed: 200ms
    Dec 22 14:37:05 pgontang_api1.gmail.com [error] curl_exec error 60 SSL certificate problem, verify that the CA cert is OK. Details:
    error:14090086:SSL routines:func(144):reason(134)
    I am unsure what all of this means. Any help is appreciated!
    Default Re: PayPay Direct Payments
    You need to get your hosting company to fix their CURL setup, because it's not accessing SSL properly.
    Jan 2006
    Default Re: curl_exec error 60 SSL certificate problem
    Excellent info! Thank you.
    I have root access....what exactly do I need to change?
    If you need help configuring your own webserver, I suggest you ask your questions via a forum dedicated to that topic, such as webhostingtalk.com
    Jan 2006
    I was just wondering what cURL settings to change. I admin my server through WHM.
    I don't know whether you can fix that by changing a CURL setting.
    Your problem appears to be that CURL doesn't see a valid SSL certificate available to it, so it's unable to establish a secure connection to an outside server.
    Quote Originally Posted by offnetrob View Post
    It's probably more of an SSL problem than a CURL problem.
    Your symptoms suggest that you probably damaged something when you "updated [y]our SSL Cert."
    Maybe you broke the server's CRT bundle by replacing it blindly?
    This is why these issues are best handled by the webserver administrator who is familiar with these aspects of web technology and the server's specific configuration.
    You may or may not have full facility in your WHM - - -
    Look for "Install a SSL Certificate and Setup the Domain" under the SSL/TLS management sidebox
    If you do not have this - - Then you can not install or manage a SSL certificate
    Jan 2006
    This is how I did setup the SSL cert. I am not sure what else to do.
    You'll need to log a ticket for assistance from your hosting company with fixing your server's broken SSL configuration, including its CRT and CA details.
    Jun 2006
    You may want to check out this link:
    sether.wordpress.com/2009/09/30/paypal-curl_exec-error-60-ssl-certificate-problem-verify-that-the-ca-cert-is-ok
    It seems paypal updated their certificate and that is causing the problem.
  1. v154 (60) SSL certificate problem: unable to get local issuer certificate
    By jokkah in forum PayPal Express Checkout support
    Last Post: 23 Jan 2017, 11:01 AM
  2. Authorize.net AIM Error 60 SSL certificate problem: unable to get local issuer
    By Jac Web in forum Built-in Shipping and Payment Modules
    Last Post: 3 Jun 2016, 03:31 AM
  3. Windows 2012 server - 60 => SSL certificate problem: self signed certificate in chain
    By QuickBooksDev in forum Installing on a Windows Server
    Last Post: 21 Sep 2015, 03:43 PM
  4. (60) SSL certificate problem: unable to get local issuer certificate
    By advancing in forum PayPal Website Payments Pro support
    Last Post: 6 Jul 2015, 02:10 PM
  5. v153 Windows server: Curl error (60): SSL Certificate problem: Unable to get local issuer
    By Nettric in forum Installing on a Windows Server
    Last Post: 13 Jun 2015, 03:23 PM
