Results 1 to 10 of 11
    Aug 2008
    Default Changing links in left box container
    Hi- this is a new installation of 1.3.8.
    domain: just better deals dot com slash cart. In the left side bar, I'd like to:
    1. remove Gift certificate FAQs. (we're not going to offer gift certificates).
    2. Remove Graphics and WebSite design were provided by Templates13.com. and move it to the footer.
    I've tried doind a search in developers tools, and can't find anything. I'm using the template 241.
    Apr 2006
    Texas
    Default Re: Changing links in left box container
    Quote Originally Posted by mel150 View Post
    Mel,
    1. admin panel/ modules/ order total/ gift certificate
    A. just uninstall the mod
    2. need a link to your site to help with this
    Aug 2008
    Thanks, that worked for the gift cert FAQ - now I need to know how to get rid of the # Privacy Notice
    # Conditions of Use
    discount coupons.
    And move that Graphics and WebSite design were provided by Templates13.com. to the footer.
    The link was given, I just don't want to make it a clickable link so it doesn't get captured by the spiders.
    www dot just better deals dot com slash cart.
    Apr 2006
    Texas
    # Conditions of Use
    discount coupons.
    Me,
    B. If client does not need Gift Certificates Link
    1. Admin Panel/ Modules/ Order Totals/ Gift Certificates - uninstall it
    C. If client does not need Discount Coupons
    1. Admin Panel/ Modules/ Order Totals/ Discount Coupons - uninstall it
    D. If client does not need Shipping & Returns & Privacy notice
    1. Admin Panel/ Configuration/ Define Pages/ Define Shipping & Returns = set to 3
    E. If client does not need Privacy notice
    1. Admin Panel/ Configuration/ Define Pages/ Define Privacy Notice = set to 3
    Aug 2008
    wonderful, thanks!
    And what about that last bit of text, Graphics and WebSite design were provided by Templates13.com? I don't want to geet rid of it, I just want to move it to the footer. Thanks again!
    Apr 2006
    Texas
    wonderful, thanks!
    Mel,
    Use this tool than the Zen Developers let you use..
    https://www.zen-cart.com/tutorials/index.php?article=39
    1. you will find the file and delete the wording in the left side box
    2. admin panel/ tools/ ezpages/ here is where you will paste the wording from the side box
    Aug 2008
    Hi- I did try that developers tool, it doesn't seem as effective as it used to. I tried it in each search field and got nothing back. (All language files, All function files, all classes files, all template files, all files-Catalog/admin.
    Each search returns:
    Warning Error: No matching Configuration Keys were found ... Graphics and WebSite design were provided by Templates13.com.
    Aug 2008
    Here's that part of the source code, if it helps?
    <!--// bof: reviews //-->
    <div class="leftBoxContainer" id="reviews">
    <h3 class="leftBoxHeading" id="reviewsHeading"><a href="http://www.justbetterdeals.com/cart/index.php?main_page=reviews">Reviews&nbsp;&nbsp;[more]</a></h3>
    <div id="reviewsContent" class="sideBoxContent centeredContent">There are currently no product reviews.</div></div>
    <!--// eof: reviews //-->
    <!--// bof: information //-->
    <div class="leftBoxContainer" id="information">
    <h3 class="leftBoxHeading" id="informationHeading">Information</h3>
    <div id="informationContent" class="sideBoxContent">
    <ul style="margin: 0; padding: 0; list-style-type: none;">
    <li><a href="http://www.justbetterdeals.com/cart/index.php?main_page=shippinginfo">Shipping &amp; Returns</a></li>
    <li><a href="http://www.justbetterdeals.com/cart/index.php?main_page=contact_us">Contact Us</a></li>
    <li><a href="http://www.justbetterdeals.com/cart/index.php?main_page=site_map">Site Map</a></li>
    <li><a href="http://www.justbetterdeals.com/cart/index.php?main_page=unsubscribe">Newsletter Unsubscribe</a></li>
    </ul>
    </div></div>
    <!--// eof: information //-->
    <div class="leftBoxContainer">
    <a href="http://www.templates13.com"><b>Templates13.com</b></a>.
    </div></td>
    <td valign="top" id="centerBackground">
    <!-- bof upload alerts -->
    <!-- eof upload alerts -->
    Aug 2008
    I found it!!!!
    thanks for rour help!!
    Apr 2006
    Texas
    Mel,
    You are most welcome, glad I could point you in the right direction
    1. I try not to give a direct answer and give hints or get you close to the answers, so you will master Zen Cart.
  1. Replies: 5
    Last Post: 4 Sep 2011, 12:30 PM
  2. Left Box Container won't show border
    By RobertG in forum Templates, Stylesheets, Page Layout
    Last Post: 1 Mar 2010, 11:59 PM
  3. Left & Right Container Box
    By electrifire in forum Templates, Stylesheets, Page Layout
    Last Post: 6 Feb 2010, 06:39 PM
  4. Changing the box header links in the left column
    By memerson in forum Templates, Stylesheets, Page Layout
    Last Post: 5 Mar 2009, 04:01 AM
  5. Changing Extra Information Page links in left column
    By kvnmcwebn in forum Templates, Stylesheets, Page Layout
    Last Post: 16 Feb 2008, 01:58 PM
